preseving the 10 bolt with n20
thanks
john
Brent
When I orderd my Fuddle I was told with the 3200 stall, full bolt-ons, 4.10's, 150 shot, ET streets, suspension, preped track, that I could spray it off the line and be fine as long as I did not launch from idle..
Quite a few guys in the 10's on 10 bolts.
More then likley I will spray off the line.
Should be one SICK 60'....
thanks
john
When I say pre load I mean you put your left foot hard on the break, give it gas slowly and you will feel the car twist a bit and the rear end raise up a little. If you give it to much gas teh car will move forward so you know when to stop.
That is pre loading.
When the light goes green let off the brake.
Go here http://hotrod.nitrous.org/indy06/
then David.wmv
Its one of my old runs and if you watch close you can see the rear of the car raise up
That would be a wakeup call to upgrade lol
-john
