Holy Shit!!
Old Nov 6, 2006 | 08:29 PM
fastest94v6's Avatar
Default Holy ****!!
I put my car on the lift today to change the pinion seal because it was leaking (again). Well as the gear oil is coming out, my mechanic notices that the oil has some metal in it. The worst part is after i put on the seal and put in about a quart of synthetic 75w 90 to top the oil off, I took it for a drive and now its making a CRAZYYYY WHINING SOUND! wtf to do!
Old Nov 6, 2006 | 08:37 PM
ski23's Avatar
DOH!!! new gears and rebuild time. my car is on jackstands awaiting new gears/bearings. goodluck
Old Nov 7, 2006 | 03:18 PM
JohnnyBs98WS6Rag's Avatar
Chunks of metal in the oil is not good. But the new noise you have is the result of not getting the pinion bearing preload reset properly, which is always a risk when changing *only* the pinion seal without a complete teardown to reset the pinion preload *properly*. Now those bearings are shot too.
Old Nov 8, 2006 | 01:43 AM
They weren't like chunks. LIke little metal dust in the oil. I'm just gonna go with some motive 4.10's along with the Ratech Deluxe kit. Should that be sufficient enough?
Old Nov 8, 2006 | 03:17 AM
JPMuscle's Avatar
depends what was starting to get chewed up, might as well as replace everything while your in there.
-john
Old Nov 8, 2006 | 04:42 AM
EPP's Avatar
EPP
This is indeed the problem, and I'm surprised more people don't have this problem when replacing the pinion seal. Bob
Old Nov 8, 2006 | 12:02 PM
yea i figured after driving the car home for half an hour.... a little too late now. what the hell is the torque supposed to be at for the pinion nut?
Old Nov 8, 2006 | 12:24 PM
jebuzws6's Avatar
Hey fastest94v6 does your car make like a winding up sound when your car accelerates and does it get louder as you go faster? I have a 2002 tran am and i think my car is doing the same noise i dont know what the problem really is but i know the noise is coming from the differential an i am wondering if anybody could tell me what the problem might be..
Old Nov 9, 2006 | 04:48 PM
Studytime's Avatar
Something like 12 inch lbs of ROLLING resistance on the pinion gear. There is no torque spec for the nut.
Ben T.
Old Nov 10, 2006 | 11:06 AM
LS1Formulation's Avatar
You have to pull the carrier out in order to properly set pinion preload. The other way to do it is count the number of threads showing on the pinion BEFORE you take it off, then mark across the pinion and on the nut so when it's tightened back down, you don't drive it on too far.
Old Nov 10, 2006 | 04:00 PM
Platinum WS6's Avatar
just go ahead and get a 9" and be done with it
Old Nov 10, 2006 | 11:00 PM
buttermantoast's Avatar
I had that problem turned out the rod to hold the axles had been grounded down and i could pull my axles out about a half inch had to do a full rebuild.
