Possible Dana 60 problems
Second, the ABS isn't working...it worked fine before. I just hope they didn't forget to install the reluctor ring like on another post I read.
Third, and this is the biggie...I think they put a spool in the car. I first noticed pulling out of the driveway that the tires were kicking up gravel. So I backed it back in the garage jacked it up...and the wheels will not turn independently. I hope to God that that's just a odd True-Trak thing. But I would hold one wheel while someone else tried to turn the other...and nothin...neither would turn. At highway speeds It felt fine...well pretty much anything over 30, and even under 30 it was just a slight stiffness you can sense in the rear. But, in parking lots the tires chirp a little when you turn sharp.
I'm going to give Strange a call in the morning and see what's up with this. Does anyone know if this is normal though?
Bummer to hear about the ABS and their respective lines. Guess the only way you will find out for sure is to pull the cover.
Something else I guess is normal with the larger ring gear is it slows down a lot quicker. There is a speed limit change I would always put the car into neutral and coast to, right when I got to the changed speed limit I would be doing it. Now, I am at the upcoming speed limit before I'm even half way to it.
I would just throw in about 4oz of friction modifier as not to acclerate clutch pack wear and to smooth it out a little bit..... but wait a few miles before you do and let work a little. You might not need very much at all if the high spots on the clutches wear off.
Sometimes it is hard to keep up with how many boards there are and whom has what problem again without re-reading the entire thread over so as not to stuff foot into mouth.
my auburn is the same way. you cant spin them independently of each other.
True-Track Stiffness, he says with worm gears instead of clutches this is normal.
I asked him about what brand gear oil, he says they have no preference as long as it's non-synthetic
ABS issues, he says their information says they installed the reluctor ring, pull the cover makes sure it's there...if it's not then they will find someone in town to fix it for me.
I asked him about the gear whine I'm getting, he says for a high performance rear end a little gear whine is normal. I have heard that any rear can be dead quiet if it is setup properly...but the noise isn't really at a level for me to make an issue out of it if it doesn't get any worse.
I ordered Motive gears and they put in Precession. He said they're the same quality. Any comments on this?
EDIT: I forgot to ask about break line length so I called back and talked with the infamous Tracey. She says most people get longer lines to go around the bigger axles. Understandable, but it be nice if it was listed somewhere in their information that this was necessary.
I'm trying to decide if I need adjustable LCAs with 26" tall tires and this rear.
