Only spinning one tire?
Old Nov 16, 2006 | 03:09 PM
Sticks1130's Avatar
Default Only spinning one tire?
This past weekend i did a couple of burnouts and both times i only laid down one strip of rubber. What would cause me to only spin my right tire? It's a 99 TA if it makes any difference. Thanks
Old Nov 16, 2006 | 04:49 PM
convexion's Avatar
I'm no expert, but my first guess would be maybe your suspension is off? Have you tried lifting the rear and seeing if both wheels spin equally when off the ground?
Old Nov 16, 2006 | 05:03 PM
98camaroLS1M6's Avatar
you broke the posi.
Old Nov 16, 2006 | 07:07 PM
SuperSport4life's Avatar
Originally Posted by 98camaroLS1M6
you broke the posi.
I'll take answer #2 ftw
Old Nov 16, 2006 | 08:08 PM
you broke the posi.
sorry for the wrong info, scratch that. I was told that when 10bolts start to go, they spin one wheel and get loud.
Old Nov 16, 2006 | 08:13 PM
Sticks1130's Avatar
So youre saying that it is not the posi but the whole 10 bolt that is giving out? Whats the best way to pin point the problem to determine if its something fixable or if its time to invest in a 9"/12 bolt. Since i dont spend much time at the track i would like to avoid going to the 9" or 12 bolt.
Old Nov 16, 2006 | 09:33 PM
keliente's Avatar
You probably have a torsen differential, and it is doing what torsens do best. It is a very wimpy diff and can't hold up to much - it just does the one wheel peel for you instead of locking down both wheels. If you are hearing no abnormal noises/sounds, chances are everything is technically ok - the diff itself is just a crappy design.
Old Nov 16, 2006 | 09:40 PM
RoysTransAm's Avatar
Turn the Traction Control on. That will fix it.
Old Nov 16, 2006 | 09:52 PM
If you rebuild your 10bolt put an eaton or auburn carrier in it, some motive gears, and moser axles, this will beef things up a little.
Old Nov 16, 2006 | 10:13 PM
Sticks1130's Avatar
How do i find out if i do have a torsen that is just weak but working properly or if i have an auburn that actually has a problem? sorry for all the questions but thanks for the help guys.
Old Nov 17, 2006 | 11:47 PM
If you take off your diff cover and see yellow springs, you have an auburn, I know 98s had them the 2000s and up I believe have a torsen.
Old Nov 18, 2006 | 11:35 PM
stroked383z's Avatar
did they not have a limited slip option for that year???
