assembling axles for moser 9"?
Old Nov 16, 2006 | 10:16 PM
SVC707's Avatar
Default assembling axles for moser 9"?
well im looking at the directions that came with it. and so you place in this order:
axle- slip backing plate on, which will kinda just be there until bolted down correct- then you slip the bearing and press on- then slide the press ring on and press fit.
BUT i got this red o ring with a gasket on it and it does not say anything about it. it does say for other years use the 1/8 spacer. its not a 1/8 spacer though.
where does this red seal/gasket go. and from what ive read, when you bolt the four bolts on thats what holds the axle in place. pushing against the bearings nothing else.
Old Nov 16, 2006 | 10:25 PM
SVC707's Avatar
btw i was also told you cant use ground controls with a moser rearend....
why is that. it wasnt too much to think about to get it done
sorry for the crappy cell phone pix
Old Nov 16, 2006 | 10:42 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Thats a nice option to consider, I have been looking into setting up swaybars onto housings like the Billingsley set up.
Old Nov 16, 2006 | 10:43 PM
SVC707's Avatar
scott, where do i put the red rings that were supplied, or do i even use it?
Old Nov 16, 2006 | 10:45 PM
SVC707's Avatar
do you have a picture of an assembled axle with everything pressed on that i can reference. my email is svc707@yahoo.com
btw this is steve i ordered my rear from you, just trying to get it assembled so i can tow the car to get my clutch installed
Old Nov 26, 2006 | 05:18 AM
SVC707's Avatar
anybody?
what gear oil to use. i have a bunch of redline 75/90......?
Old Nov 26, 2006 | 03:41 PM
jswhite's Avatar
Sounds like you are talking about the inner housing seals. They go in each housing end where the axles slide in.
Old Nov 26, 2006 | 04:04 PM
SVC707's Avatar
i got that part already, thanks though. but i just want to know what kinf of oil to use during break in.
Old Nov 26, 2006 | 05:16 PM
RPOWU8's Avatar
I have used Torco RGO 85w140 for years in my 7.5. As soon as my 9" gets here thats what is going in mine.
My .02.
DJ
Old Nov 26, 2006 | 11:10 PM
lethal93ta's Avatar
I put royal purple 75/90 in my 9 inch.
Old Nov 26, 2006 | 11:17 PM
camaromarc's Avatar
Its been awhile but Moser suggested non synthetic when I bought mine
Old Nov 26, 2006 | 11:20 PM
SVC707's Avatar
directions stated to not use synthetic, but it did not say what weight to use. ima just use some 75/90 non sythetic to break it in like they said and put some heat cylces to it. how many quarts does it take. the fill hole seems pretty low. to hold alot of fluid. some say 3 quarts. is it able to get that much in there?
Old Nov 26, 2006 | 11:21 PM
lethal93ta's Avatar
mine took just under 4 qts.
Old Nov 26, 2006 | 11:22 PM
SVC707's Avatar
Originally Posted by lethal93ta
mine took allmost 4
this was with the car level while filling it or with the rear end jacked up and the car tilted forward.
Old Nov 26, 2006 | 11:23 PM
lethal93ta's Avatar
the car was level, that was filling it till it ran out of the hole in my third member, I didnt get the fill plug installed in mine sence I had a support brace welded across teh back of it.
Old Nov 26, 2006 | 11:26 PM
SVC707's Avatar
cool thanks for the info fellas, ill get me some oil at work tomorrow and get this car rolling again finally. then i can tow it to work and have my exoskel installed and see what kind of number i finally put down.
