Moser axles and 1/2" studs?
http://www.youtube.com/watch?v=slZ1JIs3NQ4
So.....I need to upgrade to 1/2" screw-in wheelstuds.
What do I need to have done? I'm guessing take the axles out and have them drilled/tapped for the 1/2's? How much $$ am I looking at for this upgrade? Thanks
i just put in a moser 9" myself, was very upset that shop did not order 1/2" studs. they also put a spacer behind wheels and studs do not come out of the lug nuts. i think nhra wants the studs to come out about the same as the dia. of the stud.
Originally Posted by Scott@DrivelineSolutions
I went 9.90's with ARP 12mm studs in my axles. Sorry to see that happen to someone, hope it didn't hurt anything else.
LS1Tech Sponsor
Moser charges $65.00 to drill a new bolt pattern and figure in some shipping back and forth. If you had the Moser 12mm studs in there then yes the ARP studs will hold just fine.
Originally Posted by MeentSS02
HOLY ****!
I've never seen someone do that...your car launches like a **** off the two step (sounded like a two step at least).
I had the 12mm ARP's in my Moser 9" 31 spline axles... I didnt snap the studs but did this
http://home.comcast.net/~gonzon/DSC00571.JPG
http://home.comcast.net/~gonzon/DSC00564.JPG
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
~$1000 later... Yep wheel studs are definately more fun to break. Moser gives no guarentee on 31 splines ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
