Correct U-joint w/ moser and stock shaft..
Just installed a Moser 12 bolt in a 98' F-body. The U-joint that was supplied was a part # 2-1153 that came with the rear. We are using the stock shaft, for now, and was told this joint would get the job done.
It appears that the joint will fit the rear but not the driveshaft. What joints are you guys using?
Tony
Tony
Kleeborp the Moderator™
Originally Posted by inahrtbt
Thank you very much.. I'll grab one tomorrow... Tony
Hey guys... Thank you for yesterdays info.. I did go to Napa and got the u-joint today. Tried to fit it in, but it still doesn't fit the drive-shaft that is in this car. 1998 Camaro SS, 6 speed. The shaft is Aluminum and the stamping on the shaft has a spicer stamp with the #f2899 1 kae. The u-joint is a hair to big to fit the shaft. The other end of the joint fits the yoke fine. What do you think?? Tony
Originally Posted by revtime
You know the end caps have to be pressed in right? It won't just slide right in there.
We'll double check the part that Tony picked up at NAPA.
Howard
