Beefy 10 bolt?
Thanks
-Chris
In reality, it's pretty futile to try to preserve your 10 bolt. It just wasn't made to handle the kind of punishment all of us want to dish out. There is a million and one analogies about why not to put money into a 10 bolt. With that being said, you can't polish a turd, as they say.
-Chris
One thing I reccomend if you are going to continue to race on a 10 bolt.....make sure you have a spare rear or a seccond vehicle.
Just because one person had a problem with their 10 bolt doesn't mean everyone will. It is all in how it was built or whether it was treated right.
There are a couple basic thing people NEED to listen to & understand.
A) Your 10-bolt WILL break if you race on it enough
B) A 6-speed will break one very quickly on a sticky tire
C) You can get a little time out of it by spending money on it, but its like pissin in the wind.
D) A auto will let the 10-bolt live a little longer
E) There is NO possible way to make a 10-bolt as strong as a 12-bolt or 9" rear no matter what parts you put in it or brand you use.
For you believers in the 10-bolt, you will realize what those of us who have broke a 10-bolt with minimal HP levels are tryin to get through your head. Some always think there is a way around spending the money on a good rear. The only way to do this is to drive it like a regular car. No burnouts, no racing, just cruising around town/highway.
How much you think it cost on average everytime you have to rebuild the 10-bolt if you take into consideration all factors.
1) cost of new or used posi in good condition(if its worn or broke)
2) new ring & pinion gear set
3) cost to have a shop professionally set it up
I would bet $500 on the low end, thats what it cost me & I got a used posi & used gear set.
Then take into consideration the cost of this if you beef it up:
4) aftermarket axles
5) stud kit
6) stronger bearing caps
7) rear girdle
By the time you rebuild it a couple times or add all the performance CRAP sold for it, your almost to the cost of a 12-bolt or 9". Not very bright to keep investing in something that WILL break, when you could take it easy for a while, save your money & buy a rear that will hold up to abuse.
I did this on street tires & bone stock, before my mods listed in my sig.
Point is, you can always polish a turd, but in the end its just a shiny turd. Don't **** away your money on crap that will break just b/c some magazine did a article on it. Listen to people who actually have experience with OUR cars & know what they are talkin about. It will save you lots of money & frusteration in the end.
I said it once and will again.
JUST BECAUSE SOMEONE ELSE HAD A PROBLEM WITH THEIRS DOESN'T MEAN EVERYONE WILL. IT IS IN MAINTENANCE AND HOW ITS BUILT.
You keep on believing that. When you are broke down and stranded at the strip you will be like the rest of us......trying to warn others.
You can spend $500 on gears and getting them setup. Another $500 for upgraded posi. $300 for axels. Now you have spent $1,300 on a damn 10 bolt. Another $200-$500 you would have had a 12 bolt or 9inch. I could care less if you want to waste your own money. Trying to convince others to spend 12bolt money on a 10bolt.......that's stupid.
-Chris
