Why does my 9" suck
through Cartek and had them install it.
I had a brand new Detroit locker w/3:50 gears put in.
It was as noisy as hell so I thought the gears where bad.
I put in a new set and still real loud whine.
Next I scraped the locker and got a brand new track
lock.
It was quiet for about 3 weeks but slowly got louder
and louder. Now its as loud as Hell and started to grind. I
pulled it and don't see any damage.
I was WARNED that the Moser housings are made like **** and they are not square,
After measuring the rear wheel location with a nice jig my
friend had at his shop It seems to be off by 1/4" front to
back. I called Moser and they said that about 1/4" is there
typ. tolerance. How is that possible. My housing is
killing center sections left and right at 1000 bucks a pop.
I have only put 3000mi total on everything. WTF am I
going to do with this POS!
I'm in north NJ, Is there anyone around here that can check it to see what wrong with it?
Or do I buy another Moser housing and hope its better then
the first. I would switch to something else but then I would
need a new set of axles and torque arm mount because none
of the ones I've seen are interchangeable or keep abs.
Who can FIX it?
This is killing my fun, a 9" should be the one
part of my car that is indestructible.
I'm guessing the axles are going in crocked and slowly
twisting the gear setup and causing the eventual loud
gear wine. Anyone seen this problem.
I don't think its the bearings because they would have been
bad after the first center section. When I put the second
one in it was dead silent for about 1000 mi, then got worse.
The jig I used squares the tires to each other, not the tires
in the wheelwells, so one tire is 1/4" off kilter from the other.
It locks to one tire then you measure it on the other.
So the LCA's have no bearing on the measurement. I should
have remeasured it with it out of the car with the tires on
but I didn't. I guess I can re assemble it and try that, It would
will no doubt be more accurate.
I just yanked the axels and center yesterday.
. it must be a error/mistake on moslers part when building the housing. does anyone in houston know where i can take it to have the housing checked out??? i'm gonna try pyle brothers. and please if you find out what the cause is please send me a pm. and i will do the same for u.ps i have also added bmr adjustable tq arm, lca's, and panhard rod, and had it all centered/set under the car by mike at icon. no luck there.
running them on here with no problems. I also wanted to keep
the abs and all of the other housings I looked at didn't offer it.
Face it,
its not the gears,
its the housing,
It's not square.
It's JUNK!
Adjustable suspension won fix the problem... as you guys figured...
If you run a aluminum centersection after a few hundred miles and some good heat soaks it should be removed and have the lash and pre loads check and or adjusted...
I had Cartek order it and install it originally.
They charged next to nothing to install it so I just had them put it in.
I have a Currie 9" in my 71, never had a problem.
Thanks for the help, I'll make some calls..
SS
Good luck with it.
Ben T.
WELL - We got the friday at 4:30 I want to go home housings.
Another vendor is East Side Performance in CT, they have a really good rep. around here. Good luck. www.quickperformance.com
measured along the bolt holes, spun 90deg measured again, 90deg again, 90deg once more.
l<--B--->l
l==<O>==l
l<--F--->l
^ 61 1/8"F - 61 3/8"B
> 61 3/16"F - 61 3/8"B
V 61 5 16"F - 61 3/16"B
< 61 1/4"F - 61 1/4"B
Leveled the housing on my bench on jack stands, did the same thing.
spun 90 deg, 4 times, each time came out level, so the tubes seem straight.
-l-------l-
l==<O>==l
Then did the same measuring from the mounting plate ends down to the bench.
(all squared and level.)
L------- R
l==<O>==l
V--------V
got.
6 7/8"L - 7"R
7" L - 7"R
7 3/8"L - 7"R
7 3/8"L - 7 1/4"R
I'm going to send it to some pro's next week to see what they come up with.
It didn't seem to be to far out to me.
