4.10s or 3.73s??
My car has a 150 shot of nitrous, lid, TB, and will have true duals fairly soon. And I will be putting a head/cam combo sometime.
The car will be used mostly on the street, sometimes at the track..
Oh and BTW I have a M6.
Thanks
I would still get 4.10s though, cause they are the perfect gear for street and track/fun use. If you get really serious about the track times then you can get some tires to allow you to spray without shifting to 5th. Even after the heads/cam you'll be able to finish in 4th cause of the higher redline. I now trap 122 on motor, not outta gear yet and I'm on 315/35/17 Nitto drag radials.
you might be able to get through the traps with 3.90's.....i run a small cam only with 125shot and get through the traps ok on 275/40 17 tire.
4.10's would be perfect with no spray at the track.
Anyhow, trying to get out of the hole, and I mean easing the clutch out, it's just impossible to keep the tires from going up in smoke. I think I'd rather have a little less gear on street tires with primarily street driving. Just my $0.02.
