9'' or 12 bolt??
Considering the performance advantages and prices I have seen it seems like the 9'' is a good deal.
Everything bolt back up, the Moser 9 inch rear for the F Body is designed to fit the F Body.
Moser 9 Inch with Truetrac for F Body, your choice of gear ratio
Torque arm mount
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Shipped by UPS
Options:
Exciter Rings installed $100.00
Drain plug $35.00
Bob
The 9 inch weighs a little more than the 12 bolt, but the extra strength found in the 9 inch is worth it. Bob
what else will I need to buy when I buy this 9'' from you or for the 2500 is it a bolt on replacement.
Two 3.00" Napa exhaust U bolt clamps. Use the U part with the bottom part of your sway bar clamps. You will have to oblong the holes in the bottom parts, which is easy to do.
You will need Napa pn# 240-0447 1310 to a 1350 conversion U Joint, if you are using the stock driveshaft.
You will need 2 ft of vacuum line to connnect to the rear for the vent line.
Paint if you want to paint the rear. Rustoleum works very well. Thats all I can think of. Bob
The stock shaft would indeed work. The steel shaft should be stronger than the stock aluminum shaft, provided they sold you a good one, so all is not lost there. I have seen a lot of the stock 3.0" aluminum driveshafts fail. The 3.5" 1200hp rated aluminum driveshaft that I sell is a strong seller, because so many people have failures with the stock driveshaft. Bob
