c-clip removal problems
It sound like there is something holding it up right where the c-clip and the splines start on the axle.
Maybe there is something holding it at a place that you cannot see behind the c-clips. Where is is bottoming out at on the flanges?
Is there a burr on the outside of the axles from the bearing or something, that might be holding it up.
And is the rear that your tring to get the axles out of been damaged or was it in an accident?
Only asking thinking that maybe there is some other problem that you or we are over looking.
the rear end came out of the car I'm driving. It was fine when I pulled it on Monday night. When I pulled the cover there were no shavings or debri in the gear lube and the wear pattern is perfect. It seem like the axle is bottoming out on the end of the axle tube. I can hear a distinct metal to metal thud when I try to push it in with any sort of force. Man this is frustrating the heck out of me.
that's kind of what i'm think is that there may be something wron with the torsen. I put the center pin back in and it rotates and acts like it should. I took it back apart and it still won't let the axles come in. the axles only come in about 1/4 of an inch before I get a distinct metal to metal sound.
I don't see an washers that will come out. The only washers I see are the shims for the carrier.
Thanks for the bits of advice so far too.
The d. side C clip came out no problem, I've tried hitting it with a hammer, ratchet straps and a magnet with scribes. Just like Pirate I need another cards width.
I need the backing plates to put on my other rear.
Is the only solution to cut out bearsings/shims?
If so where do i make the cut?
I was then able to pick it out with a scribe. Upon further inspection the opposite axle that the first clip slid out so easily was bent. I'm stumped on that one.....
Passenger side axle bearing.
Passenger side bearing (right) for you to see how I cut it.
Driver's side axle bearing
If you've removed the ABS sensor and still can't get the axles to slide in enough to remove the C-clips, then you likely have a twist in axle in the spline area that is binding on the differential side gears. You'll need to drive the axles in w/ a hammer to remove the C-clips and then pry apart the axle from the diff end (or use a slide hammer at the flange) to free it from the side gears.
Thanks for everyones help.
