TC 's and speedo readings
Old Aug 14, 2002 | 07:10 PM
LiquidSnake's Avatar
Default TC 's and speedo readings
Hi to all;
I have a question for all A4 owners with aftermarket TC's :
I have a 98 Camaro with a Vig2800 and a few other friends haves LS1 y-body and f-body cars with Yank convertors.(Excpet for one 98C5 with a Yank 3500 convertor)we all have some speedo reading errors on high speeds.For an example my cars speedo work s very close to correct until 90-100 mph but after that point nobodys speedo reades correct mph.. i ve do some 4500+rpm s on the 4 th and speedometer still shows 110-115 mph quite funny...i ve tryed everythink(Hypertech adjusting,tire diameters,going back to stock programming...everythink...) but nothink works....anybody haves any opinions?Btw we never have a problem with our stock convertors.(i mean correct readings for the speedo)And nobodys trany is slipping.
Thanks in advance
Old Aug 15, 2002 | 07:35 AM
pekkaz's Avatar
Default Re: TC 's and speedo readings
I don't understand why a verter would have anything to do with speedo readings. If it does it must be some weird mechanism. Of course the engine rpm is higher in that speed range than with a stocker if it's not locked.
Old Aug 15, 2002 | 08:43 AM
Paul F's Avatar
Mert the speed sensor is on the output shaft of the tranny so there is no way the TC could be causing the problem. I know that my HPP III would not correct the speedo for 3.42s in my wife's car. We set it with LS1 edit and it was perfect, according to the dyno.
Old Aug 15, 2002 | 08:58 AM
Patrick G's Avatar
LS1 Tech Administrator
The speedo reads off of the speed sensor in the tailshaft of the transmission. If you are getting speedo skip, it's not because of the converter, but it's probably because the tranmission wiring harness connector or speed sensor contector has been disturbed when you did the converter swap.
The speed sensor just reads the rotation of the output shaft. It's all electronic. Check all conections. Spray them with electrical cleaner. If it continues, you may want to look into replacing the speed sensor. They're pretty cheap.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 16, 2002 | 10:13 AM
Ragtop 99's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> i ve do some 4500+rpm s on the 4 th and speedometer still shows 110-115 mph quite funny.. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Was the converter locked?...it won't be locked if your foot is deep in the throttle. If is not locked, you are seeing the shift extension of your converter. Take ATAP and measure the converter output shaft speed. My guess is that it will be lower than 4500.
Old Aug 16, 2002 | 08:50 PM
Paul @ Thunder aul thank you for the info <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I ll buy a seperate pcm from Valvegod and i ll send it to you.I think it ll be perfect.Also i ll test it for you on the 170+ mph <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
pekkaz : I dont understand 2 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . We all faced this problems right after the convertor swap .
Patrick G:Thank you for the good opinions and tips.A friend of mine haves a GM Tech II machine and he checked everythink + i put the stock convertor back on the car and speedometer shows the correct readings <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> btw : i hate my the car with the stock convertor i put the Vig back in for a few days later.
Ragtop 99 : Hmmm also thanks to you 2 for the nice tip.I ll check that asap! Btw you can bet that i floor it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> (We are checking the top speeds with a radar gun)
Old Aug 17, 2002 | 01:55 PM
pekkaz's Avatar
BTW, do you guys have european spec cars ?
I just wonder how different the programming/PCM would be. According to the advertising european spec cars have 288hp... which may just be a number though.
Old Aug 17, 2002 | 07:10 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by pekkaz:
<strong>BTW, do you guys have european spec cars ?
I just wonder how different the programming/PCM would be. According to the advertising european spec cars have 288hp... which may just be a number though.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">%80 or more percent of the cars are direktly imported from USA.The rest is from Europa.But nobody wants to buy a Euro spec F-Body they are more than ugly! Vettes rear bumpers are ugly but you must seed the Camaro <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
My car is not a Euro spec car but i understand your point.
Engines are the same but the exhaust system is a little bit different same think goes for the pollution control .But everythink works well(Hypertech,LS1 Edit...)
(In the Switzerland and some other Euro countyrs they want different oem parts and mods for an example : You cant buy a Viper with stock side pipes! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
