Ford 10.25" Rear?
Ford 10.25" Rear?
Before I get blasted with the "...you have to fab this..." and the "...you have to shorten this..." comments, I am comfortable with performing this stuff as well has anything else chassis related... so on to the post:
Would it even be worth trying to adapt this rear to work in my '02 Z28? The reason I ask is because I have a F250 sitting here with one in it...
Obviously i would have to change axles to maintain the correct bolt pattern and such, as well as fab up the spring perches and panhard/LCA brackets...
How about disc brake conversions? Anyone know if one exsists?
14 Second Truck Club
Its overall size would make it hard to fit under an Fbody, but you did say you are getting back halved. It is also going to be a power hungry rear, and probably no stronger than a built 9". You are limited on ratios, pretty much 3.73, 4.10, 4.56, 5.13. There used to be 3.55's, I dont think there are any more.
with my engine setup, i will be staying inbetween 4.10's and 4.56's anyway. my thoughts were that is is a free rear end, it has a massive ring gear, and looks to be a pretty stout built rear. a 9in would be killer, but my money is being spent else where currently and having a rear end cost me 2500+ just doesnt seem feasible to me right now. thats not to say it wont be changed at a later date though.
