Used Ring/Pinion Set Up
If I must get new ones is there a gear that is quieter than another? Oem cut vs performance cut? Best place to buy?
go to strange's site, they sell them,
performance gears usually have more nickel in the gears, making them stronger, they are also a lil louder. OEM is quiter, but not as strong..hope that helped.
if it howels though, the gear is set wrong and you should kick your mechanic in the ball sack.
for at least 10K miles now, still dead quiet and
no trouble.
OE gears will -stay- quieter than "race" gears up
until you crack off teeth, race gears are usually a
more ductile iron to take abuse at expense of wear.
Where whine is more likely to come from, is some
deformation of the crush collar from getting beat on
after the original setup. A hard pinion spacer & shims
are slightly more work at install, but will not deform.
