Moser 12 bolt 1350 yoke Spicer U-joint???
Old 08-18-2002, 09:04 AM
funeclown's Avatar
Default Moser 12 bolt 1350 yoke Spicer U-joint???
it's me again, figuring I can at least put in the driveshaft for now on my Moser 12 bolt, I bought a spicer U-joint for the beefed up 1350. This fits great into the yoke of the Moser rear but the holes on the drive shaft are ever so slightly too small!
do I need to have these holes on the driveshaft machinrd out a little to accomodate the beefier u-joint??? What doe everyone else do with a 1350 yoke setup??? Thanks!!
Old 08-18-2002, 09:07 AM
2000 Camaro SS's Avatar
Default Re: Moser 12 bolt 1350 yoke Spicer U-joint???
If it fits a little sloppy it might not be the right one. You may need to take it to a driveline shop lick I had to. I looked all over town and could not find the right u-joint.
Old 08-18-2002, 01:22 PM
The Bull
DERTY's Avatar
You need a special U-Joint for this. It's a conversion u-joint that you can get from Napa. On my car with the Spohn driveshaft I'm running a 3R to 1350 crossover. It's NEAPCO part number 2-1153. The NAPA box says 1092157-A. It's $30.
Just make sure that you get the right size opposite the 1350. If you have the stock driveshaft they may be able to help you out. I'm not sure if the stocker is a 3R or not, but I think it is.
<small>[ August 18, 2002, 01:23 PM: Message edited by: derty ]</small>
Old 08-19-2002, 01:00 PM
MIGHTYMOUSE's Avatar
above is correct, get the 1310/1350 spicer conversion from napa, or just upgrade the whole driveshaft to one with a 1350 on it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Quick Reply: Moser 12 bolt 1350 yoke Spicer U-joint???
