4.11svs 4.10s???
number of teeth
10 teeth on the pinion and 41 teeth on the ring gear (41/10= 4.10)
9 teeth on the pinion and 37 teeth on the ring gear (37/9 = 4.11)
I would assume the 4.11's are stronger as I would thing the teeth are thicker, not 100% on that one though...
I believe both are available for a 7.5 10 bolt
Originally Posted by alamantia
number of teeth
4.11 or 4.10 depends on the manufacturer, some make them 4.10's others make them 4.11. As far as strength, that is up for debate. Some say more teeth is better becuase you have more contact area from having more teeth in mesh, others like the thicker teeth. The truth is there is probably no measureable difference.
