anyone make a spool for a 10 bolt
Old Jan 17, 2007 | 01:26 AM
Taubr Unit's Avatar
Default anyone make a spool for a 10 bolt
my posi is shot and dont got the money for a 12 bolt yet. So if i can get a mini spool to get mt by for a little bit that be mint. But i cant find one anywhere, do they even make one?
Old Jan 17, 2007 | 07:28 AM
alamantia's Avatar
http://www.motivegear.com/pages/Spools/spool_photos.htm
Old Jan 17, 2007 | 10:56 AM
Taubr Unit's Avatar
"MINI SPOOL GM 7.5" 26 SPLINE"
Correct me if im wrong but isnt stock axles 28 spline? Or at least aftermarket moser axles are "stock replacement for 10-bolt" and there 28 spline.
Old Jan 17, 2007 | 12:45 PM
gator's 99TA's Avatar
dont bother. the posi is not the weakpoint.
Old Jan 17, 2007 | 12:53 PM
Taubr Unit's Avatar
but my posi is shot, cant even do donuts anymore cause its killin off 1 tire. And 1 tire hole shots. And im not looking to build it, just something to get me back goin for a little while more till i can get a 12 bolt.
Old Jan 17, 2007 | 06:31 PM
Jditlfm's Avatar
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWDVW
For $30 more he can get you a 28 spline mini spool. I have herd that you have to have an open diff to install a mini spool? I have been thinking about doing this for a long time.
Old Jan 17, 2007 | 06:33 PM
mzoomora's Avatar
14 Second Truck Club
Most mini-spools will only fit in open diff cases, not posi's. You can get a open diff case from an S10.
Old Jan 17, 2007 | 08:30 PM
alamantia's Avatar
so get one for 28 spoline, what do you want me to do?
Old Jan 17, 2007 | 08:47 PM
Taubr Unit's Avatar
well if your giving mood, make one for me then.
No need to get moody, i was just saying they dont list one for a 28 spline.
Old Jan 18, 2007 | 07:01 AM
alamantia's Avatar
i didnt mean sound moody, they make um, just order a 28 spline when you call, heres a cheep one...
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
good luck
Old Jan 18, 2007 | 07:13 AM
JNorris's Avatar
Moderator
Is this year specific or will any year S-10 carrier work?
Old Jan 18, 2007 | 07:24 AM
BLNLS1/RX7's Avatar
Check with Bob at exotic performance plus.com
Old Jan 18, 2007 | 11:42 AM
mzoomora's Avatar
It would have to be 28 spline, so 90-up. It would also have to be from the proper ratio case, so 3.23-up for most.
Old Jan 22, 2007 | 10:40 PM
Taubr Unit's Avatar
so i cant just throw a mini spool in my rearend? Its a ls1 rear with the torsen gear posi unit.
Old Nov 29, 2011 | 08:14 AM
shepss217's Avatar
i just picked up a durasolid mini spool 28 spline for $62, i thought they were all the same as long as it was 28 spline for ls1 cars
Old Nov 29, 2011 | 04:27 PM
HVYMTL's Avatar
I'm pretty sure you can't put a mini spool in a torsen, as there's no crosspin. Get out the welder...haha
Old Nov 30, 2011 | 08:59 PM
garygnu's Avatar
you mite be able to find a used posi rear end for cheap.
Old Dec 1, 2011 | 12:38 AM
01ssreda4's Avatar
4 year old thread A mini-spool in a 10 bolt is for dirt track racing, not for street use.
Old Dec 1, 2011 | 09:14 AM
BOLO's Avatar
^ Correct. I've tried doing this as well when my 10 bolt took a dump. Either find a stock replacement, or save up for stronger rear end. I went with the latter option.
Old Dec 5, 2011 | 12:39 AM
shepss217's Avatar
You can do it, you just have to pick up a 3 series open carrier out of an s10 or blazer that is 28 splines
