It's whining.....
Old Jan 23, 2007 | 11:37 PM
Magnet's Avatar
Default It's whining.....
what could be making my stock rear whine? its pretty bad at all RPM's the car only has 20k miles on it, and maybe 10 passes with nittos and almost no mods done to the car...could my rear really be going out? or do you think im just due for a fluid change w/ gm posi additive??
Old Jan 24, 2007 | 12:15 AM
xpndbl3's Avatar
you can try the fluid change, but i'm guessing the contact patch is messed up....it's 9" time
Old Jan 24, 2007 | 12:17 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If it is whining, something got out of alignment somewhere. It'll only get worse from there. Mine is slowly starting to whine more and more with each passing day.
Old Jan 24, 2007 | 12:32 AM
fuseone's Avatar
does it do it in netrual
Old Jan 24, 2007 | 12:38 AM
Magnet's Avatar
no it doesnt do it in neutral.......but what do you guys mean something got out of alignment? couldn't it only get out of alignment if something broke??
i was banking on this rear lasting for awhile, they arent suppose to go out on a stockish auto car...atleast not at 20k miles could it be a bearing?? my best 60' is onyl 1.96 and mostly run 2.00's ....those shouldn't ahve broke my rear
Old Jan 24, 2007 | 12:40 AM
Magnet's Avatar
FWIW i would be going 12 bolt not 9''
Old Jan 24, 2007 | 12:41 AM
xpndbl3's Avatar
9" is better
Old Jan 24, 2007 | 12:44 AM
Magnet's Avatar
not for an auto car...its just eating extra HP b/c im not gonna be running 9-10's for ALONG time
Old Jan 24, 2007 | 01:06 AM
xpndbl3's Avatar
eh i've seen cars go back to back with the new strange 60 and a moser 9" and run within .05 of each other. The only reason I prefer the 9" is the cheap gear change prices if the car ever speeds up or slows down in mph at the track. Also I can grab one pumpkin for the strip and another if I take the car on a long highway cruise, I also run a TH350 so no overdrive here either.
Old Jan 24, 2007 | 01:24 AM
Magnet's Avatar
yes but by what i've seen the dana and 9in both rob more power than the 12 bolt and aren't necessary for a bolt-on A4 and possibly cam only...
Old Jan 24, 2007 | 11:29 AM
switch hit's Avatar
its your pinion depth or back lash on the gears. my rear end whines like a bitch I checked the back lash and it was at .008" witch is good, but I noticed the pattern was off so that ment it was the pinion and setting the pinion suck so im going to try and blow it up. its a 12bolt
Old Jan 24, 2007 | 02:16 PM
MeentSS02's Avatar
Things can move around in there...the crush-type pinion spacer would be my first guess. Nothing has to be broken...just bent enough to throw it off. Doesn't take much...
Old Jan 24, 2007 | 02:23 PM
99zman's Avatar
when you have it fixed you can have who does your work use a solid pinion spacer to help prevent the pattern being thrown off.
Old Jan 24, 2007 | 03:15 PM
Magnet's Avatar
i'm not sure if im gonna fix it or not...i might jsut deal with it until i can afford a 12bolt....how much do you think it will cost to have it fixed??
Old Jan 24, 2007 | 04:25 PM
MeentSS02's Avatar
Depends on what needs to be replaced...the labor, regardless, will probably cost a fair amount.
Old Jan 24, 2007 | 09:58 PM
Magnet's Avatar
like $500 plus?
Old Jan 24, 2007 | 10:21 PM
xpndbl3's Avatar
depends on book rate in florida. Around here it's $90-120+ an hour....so just pulling the cover and taking a look is expensive. Setup booktime for a 10 bolt is around 5 hours depending on whether they use all-data, chiltons, etc for their labor rates. So that should clue you in on how quickly 10 bolt prices jump and there's no guarantee that it won't pop back up again. I went through 5 ten bolts running in the low 12s on sticky tires in my camaro with a 305 on spray.
Old Jan 25, 2007 | 07:05 AM
cws T/A's Avatar
launch it at the rev limiter .. thats the best way to fix stock rears .. put it out of its misery . Broke 2 so far ..1 in my 355 s10 , it got a 8.8 out of a explorer...1 in my 00 t/a , it got a 9''
Old Jan 25, 2007 | 07:22 AM
koolaid_kid's Avatar
like $500 plus?
Easily, if the gear needs to be replaced (most likely solution). If you can find a private mechanic, the charges will be significantly less. That is what I do for jobs I can't handle.
It's a "pay me now, pay me later" scenario (as to when you decide to move to the 12 bolt vs. patching the 10 bolt). I chose to pay later, but that's just me.
