Rear end noise
Old Feb 4, 2007 | 12:48 PM
playboy245's Avatar
Default Rear end noise
Hey all i have a 1999 z28 6 spd, i had the rear rebiult and now when i accelerate i get a groan and when doing above 35mph i get a high pitch whine when i back off. what could it be??? Thanks
Old Feb 4, 2007 | 04:28 PM
alamantia's Avatar
carrier bearing, pull off cover and look for shiny metal shavings
Old Feb 5, 2007 | 02:54 PM
playboy245's Avatar
I was figuring the pinion bearing or the pre load was off??
Old Feb 21, 2007 | 09:29 PM
99kamarokid's Avatar
i have the same problem, and same car... its like a high whine, and when i go faster it whines louder... did u come up with anything yet??
Old Feb 25, 2007 | 08:36 PM
chaos's Avatar
I'm ALSO having the same problem. Mine has a humming type of sound while under acceleration and starts turning into a whine after about 35 mph and only gets louder the faster i go.
Old Mar 9, 2007 | 06:52 PM
thende's Avatar
Be careful, but this works to pin-point the noise. On a road with no traffic, get the car up to 35-40 MPH and hold the throttle steady. Then slowly pull up on he E-Brake, if the sound changes, it is your outside wheel bearings.
This is per the Chevrolet Factory Shop Manual.
Old Mar 9, 2007 | 07:31 PM
well, it looks like i have to adjust my e-brake then ... it barely works
Old Mar 9, 2007 | 08:57 PM
5_02ls1's Avatar
not enough bearing preload take it back to whom ever done the rebuild make them fix it
Old Mar 10, 2007 | 06:11 AM
thende's Avatar
Pulling the ebrake, changes the load on the outside wheel bearings, if the sound changes, the noise will change significantly. You may also notice this on off ramps, as you change the load between the wheels. Good luck.
Old Mar 10, 2007 | 06:56 AM
2001z's Avatar
If you jsut had it built you need to take it back and have them fix it right!
Old Mar 17, 2007 | 05:19 AM
JEB99TA's Avatar
playboy245 ... is yours doing any of this?
I'm getting a high-pitch whine like a jetliner slowing down when coming in for a landing. This is on deceleration ... no other noises until I slow down to about 10 mph and turn slightly right or left ... sounds like a combination of tires rubbing and metal grinding. It's not coming from anywhere but the rearend. The tires all have good clearance and the neoprene bushings in my LCA's and P/H Bar have been pumped full of grease.
To verify, I took it down to the dealership and they said the setup was wrong. This didn't start until I took it to the shop to get the pinion seal replaced. It's gotten worse over the past few weeks, so, gonna' have to get it in the shop.
I have a Strange 12-bolt with 3:73 gears (A4). Rear axle seal was replaced about 6 months ago and the car only has 58,000 miles on it. I do have an adjustable torque arm. Any ideas?
