help with moser 12 install
Old Feb 12, 2007 | 06:17 PM
aequitas's Avatar
Default help with moser 12 install
so fellas, this is my first rear end install and i have hit one of several bumps in the road. I have the rear end out and the axles from the 10 bolt out. The moser says to put the caliper mount on and then the bearing with the o ring toward the caliper, then the press ring. here is the problem i am having, how do i get the bearing down around the axle where it is supposed to be? can i just use some lube and go for it? second, it doesnt look like there will be much room to tighten the bolts on the caliper mount to the housing, is there something i am missing? finally, are there any other problems that you experienced people might know of that i have not come across yet? any help would be greatly appreciated as i am trying to finish tonight before work in the am. thanks everyone.
Old Feb 13, 2007 | 04:47 AM
EPP's Avatar
EPP
Question
If you still have any questions, give us a call at 260 244-4808 and we can help you out. Bob
Old Feb 13, 2007 | 05:00 AM
RA4926's Avatar
the caliper mount is called the backing plate, you have to get the bearing and press ring pressed on the axle. took something like 6-8 tons of force to press mine on.
there is room to tighten the 4 bolts after you take the e-brake off. you have to take the ebrake line off behind the backing plate. pull the e-brake disc up until it passes the flange behind the top of the ebrake. then pull the top out an push the disc down, careful not to drop the adjustment pins. i torqued the 4 bolts on the backing plate to 34 ft-lbs. anyother questions call EPP or ask us. but its probably easier just to call EPP
Old Feb 13, 2007 | 05:05 AM
aequitas's Avatar
thanks fellas, i called my cousin last night and we used his press to get the bearing and press ring on the axle so tonight we are hoping to be able to install the axle in the housing and put everything back. however if we do run into anything ill give epp a call. thanks again
Old Feb 13, 2007 | 11:20 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I just did a 12 bolt in a friend's LS1, slightly different from LT1's, the backing plate, bolted to the axle housing was a PITA, we did pull off the Ebrake ring/horseshoe. On my car I have 4 channel ABS so the axles have to get sent out to be machined. Fun Fun.
Good luck!
Old Feb 14, 2007 | 03:36 PM
pddye's Avatar
I milled down my caliper brackets since the top thicker section is worthless since it mounts to a thinner piece of metal. With it milled you can bolt up the t-studs once the caliper mount is pressed into place. I milled the mount even with the caliper bolt holes where they bottom out.
Old Feb 14, 2007 | 11:04 PM
aequitas's Avatar
ls1>girlfriend, the ebrake info was very helpful, thanks for that.
I finally got everything bolted back up and i will be putting the DS back in tomorrow. I have read on here that it takes 500 miles for a break in but what im unsure of is if i need to change the gear oil after the first 500 miles, anyone know?
Old Feb 15, 2007 | 01:14 AM
RA4926's Avatar
here to help
Old Feb 15, 2007 | 04:30 AM
EPP's Avatar
EPP
Smile
No need to change the gear lube. Bob
Old Feb 15, 2007 | 06:31 AM
Internet Mechanic
I say this with personal exp. When my moser was installed I used the recommended gear lube, no additive (tru trac), drove it between 750-1000 miles drained the oil, clean but cloudy. This may be due to the break in period, i have been told phosperous (sp) coating on the gears.
I drove it around 1,000 more. The removed for the LT1 to LS1 swap. I just recently drained it and it was as clean as the day it went in.
Now personally there was something making it cloudy, could be something, could be nothing. I, just like anyone else spent a good chunk of money and changing the gear lube after the 1st 500-1k can't hurt anything but maybe your wallet.
Just my opinion on my situation.
Old Feb 15, 2007 | 06:53 AM
aequitas's Avatar
blackscreaminmachine thanks for sharing the experience and I will go ahead and check it after the break in and probably change it to be safe.
Now I am running into a clearance problem with the ORY. I have almost no clearance at the rear yoke and the ORY, maybe 1/8 in. Has anyone else ran into this? And when I tighten down the u joint it seems that it should be a little longer through the yoke on the read, its wide enough and fits fine width wise but it just doesnt seem long enough, is this normal or should it be flush with the yoke instead of the bolts? From the looks it just doesnt look like it would take to many heavy runs. And I know this is a dumb question but does 1350 refer to the width of the u joint or the length of the little nubs? When I got the u joint it was wider at two ends but equally long on all ends so I assumed I got the right one.
Old Feb 16, 2007 | 12:29 PM
aequitas's Avatar
well the rear end is in and running. It was a good learning experience and I am glad I opted to do it myself. It has a little whine to it but I guess most of them do. Just wanted to thank everyone for there imput and advice, I would have been stuck alot longer and some of this stuff without it so I appreciate it.
Old Feb 16, 2007 | 01:30 PM
Internet Mechanic
Hey NP and dont worry all Mosers have a whine. No biggie considering its going to take more power then I ever hope to be putting to it, to actually break it. GL!
