e brake
Old Mar 30, 2007 | 02:12 PM
blackbyrd's Avatar
Default e brake
anyone got a how to on taking the ebrake hardware off the rear end??
tried searching but couldnt find what i wanted.
Old Mar 30, 2007 | 04:35 PM
keliente's Avatar
Which part of it? Unbolt the bracket that holds the line to the rear. Pull back the little spring that attaches to the brake shoe, pop it out and that's it.
Old Mar 30, 2007 | 07:55 PM
blackbyrd's Avatar
ok im talking about the part that fits inside the rotor not any of the cables that stuff is off im talking about the part on the backing plate
Old Apr 1, 2007 | 12:23 PM
BlackScreaminMachine's Avatar
Internet Mechanic
You need to hammer off the rotor, use a screw driver to pry up on the ebrake horse shoe then pull forward over the axle flange,
Then turn down the adjustment on the bottom of the brake.
Old Apr 2, 2007 | 12:04 AM
blackbyrd's Avatar
so i dont have to pull out the shafts or the backing plates??
just pry it off
Old Apr 2, 2007 | 10:50 AM
Internet Mechanic
No, its all attached to the backing plates. The cable is a different deal, its hooked onto the back side, if the backing plate has to come off, so does the axles.
Old Apr 2, 2007 | 12:55 PM
blackbyrd's Avatar
the cable is already off all thats left is the e brake pads themselves and that little hook the cable attatches to coming throught the back. the new rear end im getting has backing plates so can i take off this stuff without pulling the axles out??
Old Apr 2, 2007 | 01:51 PM
Internet Mechanic
If it is the LS1 brake set up, you can just take the ebrake horse shoe off, as long as the meterial on the ring, isnt damaged,
Old Apr 2, 2007 | 07:49 PM
blackbyrd's Avatar
its on a v6 didnt think there was a difference as long as it is disc brakes
Old Apr 3, 2007 | 07:17 AM
Internet Mechanic
I dont know if v6's are different, I never work on them.
Old Apr 3, 2007 | 09:40 AM
blackbyrd's Avatar
thanks so much for all your help
Old Apr 6, 2007 | 04:42 PM
blackbyrd's Avatar
ok got the brake shoes off how does the hook on the back come off and the little nub on the backing plate come off or is that part of the backing plate if so my new rear end is coming with backing plates
Old Apr 9, 2007 | 10:23 PM
blackbyrd's Avatar
anyone
Old Apr 10, 2007 | 12:09 PM
Internet Mechanic
Its part of the backing plate.
Old Apr 10, 2007 | 04:14 PM
blackbyrd's Avatar
thanks alot you have been really helpful on this
