Will a 275-60-15 Nitto fit?
I was wondering if the 275-60-15 Nitto will fit on my TA? I was thinking about getting a set of these on some 15x7.5 Convo pros. I know they measure out to 28" tall. I am just wondering if these are going to hit the fender or bumper under acceleration or during a burnout? Also what will this take my gear ratio down to? I am currently running a 3.73.
Also, will my shift points be off if I go with this taller tire? I don't want to have to send my pcm back to Ed again to get it changed.
Thanks.
Jim
Thanks.
Jim
LS1Tech Premium Sponsor
Re: Will a 275-60-15 Nitto fit?
That's the exact tire that I'm going to run at the Southern Shootout for the SS/A class. I will also have mine on my 15x7.5" Convo Pros. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> You won't have any clearance problems, and the tires won't swell during a burnout or on the top-end since it's a radial. It's not going to have the soft sidewall like an ET Street or full slick.
You shouldn't have to send the PCM back to Ed Wright since your shifts should be based on RPM and not MPH now.
Trevor
Trevor
