Trans and rear-end vibrations are nuts over 100!? HELP!
Old Sep 28, 2002 | 01:52 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default Trans and rear-end vibrations are nuts over 100!? HELP!
I have an A4 with 3:73's and a Vigilante 3200 stall and Transgo. I was on the expressway and the car started vibrating really hard over 100? Why is this? Is something wrong? I can't be maxing out the gears? TC going wrong? Please help. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 28, 2002 | 05:44 PM
Dope's Avatar
Default Re: Trans and rear-end vibrations are nuts over 100!? HELP!
Suspension/alignment/wheel balance?
Dope
Old Sep 29, 2002 | 02:49 PM
Hugger's Avatar
do you have a poly trans mount? That made the console of my car visibly vibrate on the interstate. Throwing that poly mount away was the best thing I have done yet.
Old Sep 30, 2002 | 07:45 PM
HuggerZ's Avatar
I just dealt with a similar issue only I still have some vibration from another source. Try replacing your pinion bearing and crush collar. That helped me out trememdously. I had the wicked vibrations you are describing to a T.
Old Oct 1, 2002 | 12:36 AM
jimmyblue's Avatar
Moderator
Rotate your tires front<>back and
see if the vibration moves too.
