how to tell if my car has gears?
just got me a 02 ss camaro. its a m6 ls1 ss. it has 21k miles on it and a few slp parts. i have noticed that the speed is about 10-15 mph off( figured it out pacing a friend) and today i looked under the rear and noticed a ta performance girdle. is there any way i could tell what gears it has without pulling the diff? this would make sense as to why it reading so high. any help is appreciated.
www.f-body.org/gears/ Play with the calculator or get your friend next to you again at a specified speed and check your RPMs.
Originally Posted by BlackScreaminMachine
Chalk the driveshaft and turn. so many DS turns for one wheel turn.
6.84 for 3.42s
7.46 for 3.73s
8.2 for 4.10s
So less than 7, more than 7, more than 8.
well i figured it has an open diff so if i only jack up one tire it will spin. i did the test and it spun 2x and the driveshaft spun just over 6 times so it looks like i have the 3.43's but i dont understand why my speedo would be so far off.
well i have hp tuners and it said i have 3.43 stock. but the tire size was 24.94 when i calculated a 275/40/17 i got a 25.70 . so if i have stock tire size than why would it have been so small? also are the stock 3.43 a lsd?
