moser 9 inch failure
when it arrived i thought all of my problems were solved. first thing bad was a bent end where the brakes bolt up i fixed that next one of the seals was leaking i fixed that. then i took one good track run and the front pinion bearing came apart and the front seal came out. that trashed my gears and pretty much the whole third member. my stock rear lasted 7 years my moser lasted 50 miles. anyways i let bob know and he said he would take care of it.
has anybody else had this type of problem?
bearing was seated. The gears are bad for sure as well as the bearings. the
truetrac appears to be ok but after passing metal through I don't know for
sure if it will hold up. My mechanic recommends sending the whole thing back
so you and Moser can find the cause of the failure. My problem is that I
don't want to have the car down for a month but at this point I guess I
don't have a choice.
I must say though I did not expect to get this much help from you I
was ready to answer questions and accusations about my setup and install
process as well as pinion angle settings. I guess im just used to dealing
with the wrong type of people. I do appreciate your professionalism with
this situation. Please let me know what our next step is here bob. I will be
going out of town on Thursday until Monday so if we could figure it out
before then that would be a great help to me. Once again thank you and talk
to you soon.
Martin, give me a call as soon as you can. 260 244-4808. Thanks! Bob
Hope everything works out for you MyWS6... I am sure you will be taken care of.
oh and they say they dont know the cause of the failure.
