9inch and torque arm
) It probably was something messed up in the jig and Spohn actually said they had seen this before because the tubes were all over the place in mounting location on the bracket. Post pictures of the TA mounting location on the rear not at the tunnel if you have any.
that "huge chuck of metal" is a casting, so i doubt that is the problem, i'm guessing the tubes that it bolts to are off from where they should be....
-josh
pictures:
click on the above pics to enlarge, click on the below pics to do the same, twice to make them really big:
Adrian
Adrian
https://ls1tech.com/forums/gears-axles/781110-midwest-chassis-fabricated-9-inch.html
https://ls1tech.com/forums/showthread.php?t=781110
i may start doing this for my cars as well. my thoughts have always been that the company's have done all this r&d, and i'd rather have something that fits right, works right for sure than jerking around with it. but as it turns out, i've very rarely had something i haven't had to mess with anyways. i just picked up a miller div2 last month and i'm getting a dynasty 200sd in a week or two. now if i could just find a place that sells patience
