Will G2 torque arm fit a moser 12 bolt???
Re: Will G2 torque arm fit a moser 12 bolt???
It is NOT a direct replacement.
After grinding a hole in my Moser, I took my time on the second one.
1. I used a Dremel and ground a little off the bar.
2. A little off the rear.
3. And elongated the bolt holes a little.
It is a great bar. The car is so gripy that it is almost less fun now. I haven't been to the track yet, but the car hooks MUCH better now.
Sterling.
Sterling.
NO! the normal G2 torque arm does fit a moser 12 bolt. You will need to modify the arm to fit.
I did a little grinding on my torque arm and after about 5 passes at the track I ripped the top 2 bolts through the holes, it just ripped right through the metal on the G2 torque arm. I ended up having a master welder take the G2 TA and unweld the top and bottom plates with the holes and replaced them with some 1/4" thick *** steel. He re welded it to my TA and replaced the 4 bolts with longer ones since the metal was thicker. My TA is now strong as a **** and custom fitted, I can remove it and reinstall easy as pie =)
I would recommend the G2 arm its a quality piece, but if you have a Moser take it to a shop and have them unweld the top and bottom bolt brackets and replace them with thicker metal, then have them fit it on your rear.
Just my 2 cents or something.
Lee
Lee
Just elongate the holes on the torque arm some with a dremel and the holes will line up. It takes some patience and time to get it to fit, that is for sure.
