Torque rating for stock rear end cover bolts??
I am planning to change the oil in the rear end this w/e. Can anyone help me out and tell me what the torque rating is on those bolts? (95 formula) Btw I still have the stock cover, not an aftermarket one...
Just use a criss cross pattern and tighten them hand tight. Use some RTV and make sure the cover is flat.
I like to use a brass punch and knock the bolt holes back down so the cover is nice and flat; your level garage floor will do.
While you are in there get some break part cleaner and spray it down and check the gears etc... these 10-bolts are some weak mothers. I don't know what the "official" torque is, just don't go ape and break the bolts or leave them so loose that you leak.
