Trans & Diff fluid change
Old Nov 14, 2002 | 11:11 AM
DinoZ's Avatar
Default Trans & Diff fluid change
I want to change the transmission (M6) fluid and and the differential oil... what is the best stuff to use for those two?
It's only got 6K miles on it, but I want to upgrade the juices for better performance and protection.
Old Nov 14, 2002 | 01:39 PM
Fulton 1's Avatar
Default Re: Trans & Diff fluid change
I'm a Redline proponent and use their D4ATF in the T56 and 75W-90 in the 10-bolt rear.
You can look here for more specifics about Redline fluids: http://www.redlineoil.com/
Old Nov 14, 2002 | 02:20 PM
AZ28driver's Avatar
I'm getting ready to do the same thing except i have 40,000 on mine. Has anyone tired the Royal Purple products in a M6 and if so what kind of results did you see?
Old Nov 14, 2002 | 02:28 PM
5LiterBeater's Avatar
I am a redline guy myself. I changed my Tranny and Diff fluid at 38k and you can actually feel a difference in the shift. Its smoother and more accurate, but that is in my A4.
Old Nov 14, 2002 | 02:44 PM
00NBMCamaro's Avatar
redine makes some good products.. if you have a whiney rear end you can use the 90w140 redline gear lube..MTI suggested that i use that when i had some gear whine..seems to be better now..
and yeah the redline 75w-90 is the same as there tranny fluid...
Old Nov 15, 2002 | 04:52 PM
tmgxray's Avatar
Amsoil has good stuff also. I put their synthetic ATF and Series 2000 75w90 rearend oil. I felt a big difference all the way around. It felt like it pulled harder and more responsive.
That's just my 2cents.
Old Nov 15, 2002 | 05:08 PM
minivette's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by dlatwood:
<strong>I'm getting ready to do the same thing except i have 40,000 on mine. Has anyone tired the Royal Purple products in a M6 and if so what kind of results did you see?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I used Royal Purple and it's smoooooth. Although, if you do a search, it seems 50/50 the results. I have heard the best syn fluid to use in the T-56 is made by Honda.
Old Nov 18, 2002 | 03:10 PM
DinoZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dr Debacle:
<strong>I used Royal Purple and it's smoooooth. Although, if you do a search, it seems 50/50 the results. I have heard the best syn fluid to use in the T-56 is made by Honda.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've heard somebody say that about the Honda fluid, too!! I just want to get as many 'experianced' opinions as I can, so I can do the best thing going.
Old Nov 20, 2002 | 06:51 AM
tmgxray's Avatar
Use amsoil synthetic ATF and series 2000 75w90 rearend oil. They are suppost to be a lifetime fill and the rear end fluid can be used with out adding limited slip additive.
hope that helps.
Old Nov 21, 2002 | 02:36 PM
DinoZ's Avatar
Thanks for all of the info guys!!! <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
