wheel bearing replacement?
Wheels
caliper with brackets
rotors slide off
removing shocks will drop the rearend down some along with sway bar end links.
Rearend cover. (may have to remove panhard bar for easier axcess)
8 mm bolt in center pin.
center pin slides out
Then push each axle inwards to releave pressure on c clips
use magnet to pull out c clips
Axles will then slide out
use seal puller or end of axle to remove seal
then use slide hammer to remove axle bearing.
More than likely if it's bad the axle will be trashed too.
can usually use old bearing to hammer in new bearing .
use flat wood or proper tool for seal.
good luck.
..refill at end. haha
For cars with TCS, the reluctor rings are pressed on the axles. Just don't drop the axles when you remove them and you should be fine. Before removing the C-clips, you need to remove the speed sensors first. Otherwise you won't be able to push in the axles far enough to remove the C-clips. You'll know what I'm talking about when you actually see them. The speed sensors are on the brake backing plates.
BTW, if you are replacing wheel bearings only, you probably won't need to remove the shocks to lower the rear end. It should drop low enough even with the shocks on anyway.
But as for putting in the new bearings and seals...
I rented a tool from autozone that has an assortment of round aluminum disks. I put the tapered end up against the bearing and pounded it in until the outer rim of the aluminum disk hit up against the axle tube. Then I pounded the seal flush.
Did I do it right? Should I have put the bearing in as far as it goes?
You can use the old bearing and a bearing driver. You will know when the new bearing is fully in. It will be like hammering a wall that doesnt move and be very solid.
Those tapered bearing drivers arn't the best for axle bearings bc they sometimes bottom out before the bearing does. If it's not down all the way and the seal is in, you're probably not gonna have any chance of saving the seals.
Make sure you have some grease on the bearing and seal so it's not dry.
Good Luck.
