Shift extension question
Old Nov 25, 2002 | 09:02 AM
JNorris's Avatar
Moderator
Default Shift extension question
On my 98 Z28 with an YPT4000 and 3.23 gear my 1-2 and 2-3 shifts take place at 6200rpm and the rpm drops to 5500 after each shift. If I lower the shift points will that reduce the shift extension?
The reason I want to do this is because the car pulls like mad between 5500 and 5900 with a real sweet spot at 5700. I can feel it drop off quickly when it hits 5900. I currently have the shift points set at -1mph on the 1-2 shift and -4mph on the 2-3 shift with the rev limiter set at 6400. I have them set this low because I was hitting the rev limiter.
Thanks
John
Old Nov 25, 2002 | 02:04 PM
JNorris's Avatar
Moderator
Default Re: Shift extension question
Thanks for the reply. I thought that would be the answer. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
But just to be sure I will lower the shift points and see how much it changes. If I can lower the extensions by a few hundred RPM then I will be happy. And maybe a 1/10 faster! <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Thanks
John
Old Nov 25, 2002 | 09:00 PM
Ragtop 99's Avatar
You want a high shift extension; not only are you making near peak HP, the converter is multiplying torque.
I'm not saying that lowering your shift points won't work; but higher shift points let the gears multiply torque. The 1-2 shift has a big gear drop. If you have headers and a good exhaust, I'd experiment with a 6200 shift point too, even if it doesn't pass your SOTP test.
Old Nov 26, 2002 | 12:52 AM
Patrick G's Avatar
LS1 Tech Administrator
Shift extension is more dictated by engine torque than rpm. Lowering shift points will not lower your shift extension very much unfortunately.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
