2:73 to 3:73
Old Aug 14, 2007 | 05:12 PM
95camaroz28's Avatar
Default 2:73 to 3:73
I have a 95 Z-28
A4
Now I have 2:73's and I want to go to 3:73.
My car has 122,000
What gears are best
and what do I all need to do the gear swap?
And what is the cheapest way to change the gear ratio?
By hyper tech? Diablo? Just send in to PCM for less? I have headers,GMMG, CAI..
Old Aug 15, 2007 | 12:18 AM
monzaz's Avatar
Default Gear swap
Well first off - you have a 2 series carrier with the 2.73 gears. So you will either need a 3 seires carrier or a 2 series 3.73 gear. If your bearings are good about all else you will need is maybe some shims for the new gear set. pinion and carrier. The likely hood the new gears set will be exactly in the same pinion depth and side shimming ... is slim to none chance. A dial indicater if you can borrow will make life easier on the backlash settings which is a must to keep in the .005-.009 range. Time and patients will also be another must.
Jim - J D race.com
Old Aug 15, 2007 | 09:55 AM
So what is the easiest way to edit the computer for gears?
Or maybe I should get 3:42's....
Old Aug 15, 2007 | 11:27 AM
alamantia's Avatar
PCM tune
Old Aug 15, 2007 | 11:34 AM
HasselZ28's Avatar
He newbie here, I kinda have the same question I have 2.73 gears in my 2002 Z28 and wanted to go to 3.73. I am going to have them professionally installed and would like to save some money on purchasing the parts what exactly would I need to get and where oh yeah and about how much am I looking at?
Old Aug 15, 2007 | 04:55 PM
AK47's Avatar
I would go with Motive. They dont whine as much as Richmonds. $180. Install kit ( good idea to get one) $90. Install runs between $250 to $300
Old Aug 15, 2007 | 05:20 PM
MikeSomething's Avatar
I bought used Richmond's, man do they whine! I bought them w/ a Master install kit for $100.00 on a forum, so I'd look there 1st. Usually a set of gears and kit is double that...
Old Aug 15, 2007 | 07:28 PM
Formula_Power's Avatar
you will need 3.73 gear set and some kind of install kit hat will include shims...gaskets.seals...etc etc i would go with 3.73s trust me you will think your driving a different car going from 2.73 to 3.73....you will be able to break the tires loose at will with that upgrade
Old Aug 15, 2007 | 08:48 PM
sixvi6-camaro's Avatar
Stickys are your friends.. all the info is in the REAREND FAQ...
