Part number location?
I bought a used Auburn LSD differential to upgrade my brother's 1996 Camaro RS which currently has an open differential with 3.08 gears.
I just need to know if this is a 2 series or 3 series carrier so we know what gears to buy.
Does anyone know where the part #'s are on these things?
It has a bunch of numbers on it, but the only one that brought up anything was the 4612825 US Patent number.
Any help would be greatly appreciated.
LS1Tech Sponsor
You might have to make a call to Auburn and have them tell you the series and spline count as well. You can also dissassemble the 10 bolt and stand the 2 side by side on a flat bench or piece of steel. Your 3.08 is the 2 series and if the Auburn is .250" taller then it is the 3 series.
Can anyone verify this now? Ive found a Auburn carrier that has 13/42 labeled on the ring gear so I know its a 3 series but is it the good auburn carrier or the non wanted one. The only #'s besides those gear ratio I can find is 4612825. It was removed from an V6 firebird so im not sure if its a posi or not
