WTF @ Moser 12 bolt
WIKIPEDIA definition: "Safety wire is common in the aircraft and racing industries as an extra precaution to keep vital fasteners from loosening and parts falling off. Safety wire is commonly .020, .025, .032 or .041 inches in diameter and usually made of stainless steel, but is also available in Monel and Inconel alloys for high temperatur applications and copper for break-away applications. It is threaded through a hole drilled into a fastener or part, then twisted and anchored to a second fastener or part, then twisted again, usually with the aid of safety wire pliers."
Amount other things I have accomplished in my life... I also have an A&P. I also spent a few years in Military Aviation... wrapping saftey wire by hand. Saftey wire is not for visual inspection... it is there as a means to prevent a fastner from coming loose and falling off.
If you have ever been part of a reclaimation team cleaning up after one of our boys, that stuffs a $25 million plus airframe into mother earth... you will have witnessed that when you go to pick a frag up... the only thing holding it together IS THE SAFTEY WIRE.
Please... do not spread misinformation.
