Intalling TC and Headers next week.....
Vig 3600
B&M trans cooler (24000)
New filter and gasket for trans
JetHot LT's w/ out emissions
Emission tube block off plate
what else will I need? How many qts of trans fluid? And anything else you can add would be great!
Use Red Line tranny oil - about 5 quarts. buy 7 just in case.
You are missing a huge component in the tranny performance upgrade - the shift kit. Get one from TCI.
From what???? I shure as hell hope that doesnt happen to me!!! I have no idea why. My converter is still pink which means it didn't die (hopefully). But I have no idea why it just gave out like thay. Make sure the installer prefills the converter with fluid before installing it.
Oh and i did go through the proper breakin and everything. All my friends are runnin 3200, 3600 stalls and they're doing fine. Maybe my tranny was a lemon?
One more thing I can suggest is working on your intake and exhaust mods. THe converter LOVES to stay at high RPMs. After a shift, it would flash to 4800. So you need to have good air flowing into the engine so it doesn't choke. HIGHLY unlikely it will happen, but it is possible.
BigBlackZ28: I can't see that the converter itself caused the problem...your car is newer than mine. Who did the install? That is just so weird to me
I would (and do) use regular dextron III oil. Better to use dino and change it more often. In fact, if you are on factory tranny fluid and filter, I'd change them while doing the the TC install.
Some headers need O2 extensions, I don't know if jet hots do. If you are not running cats, you need O2 simms (or LS1Edit).
I will either be having it installed by Andy's Auto or a reputable transmission shop.
For the first few days, man the converter rocked!!
I think I was just low on tranny fluid (didn't check it often) and the tranny just died.
No clue... but it is going in again in a few weeks.
Yeah I knew about the O2 extension, thats one of the reasons that I bought in on LS1 Edit
Thanks for the info .... keep it coming
This thing hits the tires very hard on the launch,be prepared to buy tires (alot).
I run 315/35/17 Nittos,and have yet to get a good 60 ft time due to driver error.
Good luck.
Dave
