is there a write up on a rear end swap?
<small>[ December 12, 2002, 06:02 AM: Message edited by: Edge Hawk ]</small>
jack up car, take off rear cover, rotate rear until you see the small bolt for the large pin in the center of the posi, take out this bolt and tap the pin out of the posi, after that you should be able to push in the axles to release the c clips and then pull out the axles.
that should get you through it.
<strong>hmm,
where are you doing this mike?
it's cold as **** outside.... LOL
David, thanks, but i meant the whole rear end... LOL.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mom's garage. If you're nice I might even shell out for a space heater <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Mike
p.s. I think Dave is explaining the only complicated step in a rear swap. You have to pull the axles to get the rings removed and pressed on the new axles.
<small>[ December 12, 2002, 10:04 AM: Message edited by: buschman ]</small>
I can bring that, but i don't have any sockets.
here's what i have.
stock 7.5" with 3.23s in the car.
I have another complete rear 7.5" with 3.42s minus the backing plates.
i just like to have instructions to go by, just in case.
