3.73's are howling like a &^%$
When we first did the install (my buddy who helped me do all the mods is very experienced, and has done many rear ends) we set up everything to spec, backlash was an average of 8 thousands around the carrier. I took the car out for its 1st drive and right about at 15mpg and all the way up it screamed and howled on accel, decel and cornering. So we went back in and removed all the shims from the pinion so its as far back in the housing as possible, and re adjusted the shims on the torsion. Off hand I can't remember what the final backlash was, but it was more than before. So we took it out again and it still screamed and howled on accel and decel... seemed to be worse on the decel this time around, and the cornering was quite I believe.
Is there anything else I can try to do to get it quieter?
I was ready to buy a 9" or 12 bolt this morning (originally I was going to do this next year) until I read all the problems everyone has had and the fact that it takes 6 weeks to get delivered isn't helpful either. Any suggestions\info\help would be great.
DKL
My buddy was talking to his friend who is also a great mechanic. He suggested re measuring the housing and find its true center point to make sure our measurements are correct, as you suggested... which we also did again yesterday before we removed the pinion shims. To do our measurements we ran a straight piece of iron across lower mounting holes for the torsion brackets(the surface that the 2 brackets that hold the torsion bearings in place at each axle opening in the housing), and then measured from the bar to the pinion to get its depth.
Does this sound correct?
Since the mating surface is usually not precisely on the carrier bearing centerline, the difference (offset) must be measured and either added to, or subtracted from, the measured distance, to determine actual pinion depth.
To determine the offset, measure the carrier bearing race and divide it in half. Then measure the distance from the bearing cap mating surface to the bottom of the bearing bore. The difference is the offset. If the measured distance is less than half the face diameter, the difference must be added (to the pinion depth measurement) if it's more than half the race diameter, the difference must be subtracted.
As an example, half of the 3.064" diameter race used in a Chevrolet 12-bolt rear axle is 1.532". If the distance from the mating surface to the bottom of the baring bore is 1.512", the surface is .020" below the bearing centerline, so .020" must be added to the measured pinion depth to determine the distance from the back of the pinion to the carrier bearing centerline (pinion depth).
