Midwest Chassis & Performance fab rearends... new pics
#2601
Just wanted to say I recieved everything today and what an awesome job they did! I ordered mine disassembled and when I went to lift the housing out of the crate I almost threw it over my head, MUCH lighter than I was expecting. Gotta get some new brake lines and backing plates and Ill be good to go. The red and black look sick!
#2603
LS1Tech Premium Sponsor
#2604
OK I miss understood the shop guys on what they were doing. It isn't that fitting they couldn't find it was that fitting to a -3 to use braided line. Since a ton of people ask about braided line over bending up steel line for convenience and appearance.
Sorry for the confusions, way to many things to try and remember some times.
#2606
This is not copper tubing, hence the copper nickel comment earlier. It is one of the best brake line materials due to strength and corrosion resistance.
It was originally developed by Volvo, known for unsafe designs.
Used on Porche, Audi and Aston Martin's, also known for poor performing brake systems.
http://www.agscompany.com/automotive...nes/nicopp/353
http://www.agscompany.com/faq
http://www.agscompany.com/faq/11
#2608
Pretty much done.
I put a little extra effort into the little details. New brake lines, new ebrake boots, reloomed the wiring harness and painted the Strano sway bar and brackets.
All I need to do to finish it is wire tie the wiring harness to the brake lines and I am looking to see how the Kooks true duals will sit over the axle and see what needs to be done to the heat shields. Tried to clean the underside of the car, but it still looks dirty to me. I will take some pics as it is, it wll be easier to see the install with out the exhaust and DS installed.
Also going to modify the current housing vent. I had issues with the Moser diff puking oil in long sustaing right hand turns, it pushed the oil out the vent in the drivers side axle, I would think I will have th same issue with this if I leave it. What I did to fix it was run a hose from it up and towards the passenger side. The oil can not defy gravity or the laws of physics then.
#2609
Pretty much done.
#2612
Pretty much done.
#2618
First off me and paint do not get along. My under hood painting project has been the delay of the motor install.
Anyway here are some pics of it installed, told you it was dirty. Sorry all the parts are black so it pretty much soaks up all the light.
All my pics of the my MWC 9" are here.
https://skydrive.live.com/?cid=6fae0...2846&sc=photos
#2620
Anybody ever have clearance issues between the console and a pro 5.0 shifter after installing the mwc trans crossmember? After installing my trans crossmember the ring on my shifter is pressed into the bottom of the console. (transmits a little bit of noise..../sarcasm)
