Midwest Chassis & Performance fab rearends... new pics
Old 03-09-2012, 06:29 PM
  #2781
Brian2001SS's Avatar
Question for fab nine experts. I saw a post on this earlier, but not sure it was answered.
The helm joints on the tq arm have me puzzled. In order to bolt it up I had to unscrew both joints almost all the way out. You can see in one of the pictures how far it's out. Any ideas on if this is the right direction?
And by the way, the setup is coming together. I'm so excited. That red rear looks so awesome with the black tq arm.
Old 03-09-2012, 07:44 PM
  #2782
flintwrench69's Avatar
Youre talking the botom heim joint? I didnt have to do that on mine. I thought I had my GMMG shinin pretty good but yours looks like chrome. What did you use to get it looking like that? You have a sick setup there
Old 03-12-2012, 05:00 PM
  #2783
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Originally Posted by ramairws6
What size gear and brand did you go with? Yukon and 4:10??
Think Yukon with 3.00 gears.
Old 03-12-2012, 05:15 PM
  #2784
Finally got it up in there, but ran into a problem. Has anyone had a problem with the coil over springs hitting the brake line and bracket? Here is a picture of the rear and the brake line.
Here is what I'm concerned about.
Old 03-13-2012, 01:22 AM
  #2785
Stang-Slayer's Avatar
Wow.....looks great man but you are definitely spending too much time and money making an underside of a 4th gen look outstanding......to each his own though....damn it looks great
Old 03-19-2012, 04:32 PM
  #2786
Blwn_by_Twins's Avatar
Got tracking numbers today!!!
Old 03-19-2012, 06:55 PM
  #2787
99french's Avatar
I wish I would have done a fill plug
Old 03-20-2012, 04:27 PM
  #2788
Quick question guys. Is this the correct order and facing for pressing on the bearings? I know I need the backing plate on there first, I'm just wanting to make sure about the order and that I have the actual bearing facing the right way.
Also, I'm running a spool, so is it ok to run synthetic gear oil?
Old 03-20-2012, 09:36 PM
  #2789
LS1Tech Premium Sponsor
ssvert99's Avatar
bearing order is correct. make sure to put the left side backing plate on the short axle with e-brake shoe facing the flange. right side on the long axle, brakes the same.
your tag on the center section says "use 80/90w NON synthetic gear oil" for a reason. Synthetic oils are not reccomended during the first 500 miles on a street rearend. After 500 miles if you want to use the synthetic feel free.
Old 03-22-2012, 09:45 PM
  #2790
Somebody tell me what I'm doing wrong. I can't get the shock to fit. The mounts aren't wide enough to fit the bolt or the shock.
Old 03-22-2012, 10:31 PM
  #2791
Zmg00camaross's Avatar
Sometimes that powdercoating can be a issue because of the thickness.
Old 03-23-2012, 02:24 PM
  #2792
djfury05's Avatar
Yep I had to clearance a few things because of that.
Old 03-23-2012, 03:05 PM
  #2793
Spoke with Eric. Strange sent me shocks with bushings instead of bearings. He sent me the right parts out today.
Old 03-24-2012, 09:16 PM
  #2794
hiimnewhere's Avatar
instead of calling and bugging them at the shop... for those of you who had them assemble the rear, how much extra did the freight cost? Not the cost of assembly
Old 03-24-2012, 10:31 PM
  #2795
transam69230's Avatar
Wasn't any extra, its built into the cost of the extra assemble charge.
Old 03-26-2012, 11:03 PM
  #2796
konceptracin's Avatar
Sneak peak... Don't mind the mess, cars undergoing some major changes
+1 mwc top notch work!!!
Old 03-27-2012, 03:34 PM
  #2797
miss.mod.46's Avatar
This is correct....no extra freight costs, it is included in the assembly charge. When ordering a complete rear, unless noted, any options you add from the price list will not add extra freight costs.
MWC fabricated 9" pricing
Old 03-27-2012, 06:06 PM
  #2798
Ok guys, I know this has been mentioned in the 70 plus pages, but has any of you reused you emergency brake cable brackets off you 10 bolt? If you did, any pics? I know, that's pushing it now.
Old 03-27-2012, 07:29 PM
  #2799
djfury05's Avatar
No.. I didn't reuse those brackets.. I just let the cables hang over the backbrace. They are pretty sturdy though.
Old 03-27-2012, 08:07 PM
  #2800
LPE 403's Avatar
Best I have for now Brian....like djfury, just draped them over.
Quick Reply: Midwest Chassis & Performance fab rearends... new pics
