Midwest Chassis & Performance fab rearends... new pics
Old 06-14-2010 | 06:26 AM
  #1801
Paul Bell's Avatar
That's MISTER MODERATOR
It looks like one of the aluminum ones. I wanna know what sway bar is that.
Old 06-14-2010 | 09:26 AM
  #1802
DiabloFormula's Avatar
The panhard bar is just some no name one off eBay that I bought years and years ago....its also double adjustable. The drag sway bar is Midwest chassis
Old 06-30-2010 | 10:08 AM
  #1803
ssvert99's Avatar
LS1Tech Premium Sponsor
the drag anti-rollbar option is a great addition to the rearend package if anyone is looking for optimum drag strip performance, and is streetable for the most part. it is constructed from the exact same materials we use on the 200mph top sportsman cars and is a huge weight savings over most of the other "extreme" arb's out there. it is a direct bolt-on to our ever popular fabricated 9 inch, Moser's 9 inch, stock 10 bolt, 12 bolts, and even the S60! the tube design varies a bit but all bolt to any rearend with stock style brackets in place. we include a set of either weld-on tabs to go to the back of the frame rail or we will have ones available to bolt to the stock location for a 100% true bolt-in setup.
Old 07-01-2010 | 11:37 AM
  #1804
Mustang Hat'r 2's Avatar
Add another owner to the list. Got one with 35 spline full spool and 4.11's coming. Its a long wait but after seeing the weight and other issues with the other 9's its worth the wait. Will post pics before and after install.
The anti roll bar is the weldin version better?
Jay
Old 07-15-2010 | 10:06 AM
  #1805
ssvert99's Avatar
the weld-in version does have a slightly lighter weight bracket that attaches at the frame and it is a real easy install. once the bracket is attached to the frame the arb becomes a full bolt-in. there is never any welding required on the rearend because we install the sway bar brackets on all of our rearends at no extra charge.
Old 07-15-2010 | 07:09 PM
  #1806
z28_theantirice's Avatar
Man these Fab 9" are gorgeous, wish I had the $$$
Old 07-16-2010 | 12:49 AM
  #1807
SHovV's Avatar
what are the benifits of a rear sway bar of that design on a daily driver as compared to something like bmr's xtreme rear sway bar? mwc's bar looks like a stronger set up maybe
Old 07-16-2010 | 10:35 AM
  #1808
chon79's Avatar
Whats the order time on a rear with no powdercoating?
Old 07-16-2010 | 11:08 AM
  #1809
ssvert99's Avatar
i'm not sure there is much of a "strength" difference as the BMR, UMI, Spohn, etc type solid bars do work. only drawbacks i see with that design vs our tubular chromemoly style is the reaction time(a bent bar & arms will be slower than a straight tube and straight arms), and the biggest fact is our design is 19 pounds lighter! we also use a double shear type(brackets on both sides of the heim joint) mounting setup where the solid type bars use a heavy plate with a 5/8" bolt welded to it with no outer support. this is a point where flex will happen.
Old 07-16-2010 | 12:31 PM
  #1810
chon79's Avatar
Thanks for the PM Eric. I responded.
Old 07-19-2010 | 10:15 PM
  #1811
My2ndls1's Avatar
Just ordered mine, Can't wait to get it!
Old 07-19-2010 | 10:51 PM
  #1812
MIGHTYMOUSE's Avatar
hey eric just wanted to say thanks for the deal on the rims.
ordered the rims thursday afternoon (sold out most places) eric had them at my house today. second perfect wheel purchase from you in a row. good job.
look for a rim post comming soon
Old 07-19-2010 | 11:44 PM
  #1813
veee8's Avatar
FYI.....
I piloted another Midwest Chassis Fab 9 equipped Trans Am to a 1.29 sixty foot on its way to a 8.84 pass a couple of weeks ago. Low 1.30's are the norm.
Running a MWC 9", spool, 35 spline, 3.0 gears, MWC ARB, and short torque arm with double AFCO's all the way around.
Still setting everything up, and we expect 1.15-1.20 60 fts. when everything is dialed in. Street car.
I will be continuing to run the MWC 9" and long torque arm, LCA's etc.. on my personal outlaw radial car. Gunning for sub 7 second passes in that car.
Old 07-20-2010 | 01:13 AM
  #1814
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Are these rears good for a full street car? I'm trying to set mine up to handle well and also have a drivline that'll hold high hp.
Old 07-20-2010 | 02:41 AM
  #1815
Zmg00camaross's Avatar
They would be fine on the street. You could go with a watts link rather than a panhard bar.
Old 07-20-2010 | 04:34 AM
  #1816
Mine handles great great....little rod end noise from the drag bar but thats expected.....even on these beautiful PA roads....
Old 07-20-2010 | 08:44 PM
  #1817
jerflash's Avatar
i have to say that i have eric'srod ended Panhard and LCAs and i have no rattle noises on crappy NY roads....love my rear
Old 07-20-2010 | 09:30 PM
  #1818
penningta's Avatar
Just some of the parts we picked up from Eric
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 07-21-2010 | 03:10 AM
  #1819
Here is mine, Bought all from Eric besides the K member.
Attached Thumbnails Midwest Chassis & Performance fab rearends... new pics-mwc.jpg
Old 07-21-2010 | 01:54 PM
  #1820
SIC LSX's Avatar
thats some $$$$$$$$$$$$$$ right there!
