May be dumb
Old Jan 28, 2008 | 04:12 PM
t/a for life's Avatar
Default May be dumb
I just picked up a 01 ws6. Cam, patriot heads, pacetter headers, lid, ls6 intake(well thats stock), and 4.10's. I have the dyno sheet it made 442 to the wheels and i know the guy took awsome care of it when he had it. My question is what happens if it has the stock rear end. I would love to take it to the track but scared to cuz it may break. Dont know how to tell if it has a different rear end in, it. If you could answer that thxs if not thank you for reading
-Travis
Old Jan 28, 2008 | 05:39 PM
RareBreed0295's Avatar
It should be fine as long as you just slip the clutch. I wouldnt drop the clutch when putting out that much hp.
Old Jan 28, 2008 | 05:46 PM
snake charmer's Avatar
just be carefull is all you can do . if you go to the track try not to launch hard and just take it easy if that makes sense . some stock rears hold up and some dont . there are folks running 400+hp that have not had problems .
to check to see if it is the stock 10 bolt , look under the car in the back at the the round center section . as you may of guesse the stock center section will have 10 bolts . every aftermarket rearend i have seen is powdercoated (usually black) and i would of thought who you bought the ride from would have advertised the aftermarket rear as they do cost a bit . hope this helps
Old Jan 28, 2008 | 07:20 PM
02silvaZ's Avatar
be very very careful unless it is aftermarket, thats a catastrophe waiting to happen
Old Jan 28, 2008 | 07:23 PM
Thxs for the info guys. Bad thing is i think it is a stock 10 bolt rear end which worries me haha. But if i ever went to the track i wouldnt be launching at a high rpm anyway. But again thxs for the info guys
Old Jan 28, 2008 | 11:50 PM
SweeTbone's Avatar
Always be afraid. I am. As stated, slip the clutch, try to avoid wheelspin and the 1-2 shift will probably have a pretty solid clunk to it. You should be fine. Although I haven't been to the track with my setup either.
Old Jan 29, 2008 | 09:43 AM
Steve Burger's Avatar
LS1TECH Sponsor
Be gentle on that rear. We have a number of upgrade options if you are interested. Let me know.
Old Jan 29, 2008 | 10:09 AM
Jawsgear's Avatar
-Travis
Not really a matter of if but when. If you plan on beating on thecar at the track be prepared to upgrade the differential. Let me know if you have any questions, or when your ready to upgrade give me a call. We will be happy to help you out.
Jeff
Old Jan 29, 2008 | 11:26 AM
One Bad Z's Avatar
Run it hard till it breaks or replace it before it does. What's the point of having a fast car if you have to baby it? Gotta pay to play. Get a driveshaft loop if it doesn't already have one.
Old Jan 29, 2008 | 01:56 PM
Gary Z's Avatar
i think it is a stock 10 bolt rear...
Look underneath and count the bolts that secure the rear cover. If you are running street radials (not drag radials), a 10-bolt rear will survive a trip to the track. Your ET will suck but you could have fun and learn how fast it will go. Unless your car is extra heavy, you should trap above 115.
Old Jan 29, 2008 | 02:55 PM
Ill be running on street tires really so wont be hooking to good anyway.
Old Jan 29, 2008 | 03:44 PM
Johnnystock's Avatar
I wish it was that easy...but true
Old Jan 29, 2008 | 05:09 PM
EPP's Avatar
EPP
Thumbs up
-Travis
Travis, you're not too far away from us. We sell more Moser rearsends than anybody on here, give us a call at 260 244-4808 and we can help you out.
Bob
Old Jan 29, 2008 | 07:30 PM
austin21's Avatar
I see you're from IN just wondering which track are you going to?
Old Jan 29, 2008 | 09:02 PM
I like Indianapolis Raceway Park, or i go to cleves, oh to Edgewater
Old Jan 30, 2008 | 06:47 AM
BOLO's Avatar
+2.....
Old Jan 31, 2008 | 04:33 AM
EPP's Avatar
EPP
You'll have to try out Muncie Dragway this year. Muncie Dragway was sold to a guy from Indy who is putting a lot of money into the facility. He had it repaved last Fall as the first step. Bob
Old Jan 31, 2008 | 06:27 AM
Smoke346's Avatar
The way I look at it is, you aint having fun til you break something....then you'll know if you need to upgrade. Im bout to put 4:10s in my stock rear and Im gonna give her hell, why not? Bunch of guys in the Fbody club Im in are running mid 10s to low 11s with stock rears and they are holding up so far...Good luck and have a trailer nearbye...
