Deep Trans Pan?? worth it? help any?
Im getting ready to change my trans fuild again and would like to put this on while im doing it.
Even with the cooler, this 3600stall still heats up the fuild alot when racing
bolted on yet) that didn't come with a
pickup extension. Seems like that would
be a plus, anyone know where you'd get
something like that (by itself)?
the extra 3 quarts should help alot though <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I have a dearle. The price is good and it adds capacity and some extra cooling capacity. Ground clearance is good
TCI has cooling fins that I like and adds 2 qts. Had the price been the same, I would have gotten the TCI.
It DOES Work and it DOES help, noticeably!
I can hot lap my car on a freeway all day long and temps stays low; it also helps alot in San Francisco (if you have been here you know how huge the hills are in here and how hard they can be on the tranny)
The only drawback is that my car is lowered and i scrape it from time to time over the bumps or other crap damn it <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
PS. Deep pan seemed to keep my crusing trans temps down by 15-20 degrees. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong> I have the GM deep truck pan with drain plug. I got it along with my built trans. I didn't put enough miles on the trans last year to need to change the filter but I would like to this year. So I'm wondering, what filter are you guys with GM truck pans using? I think I remember someone telling me to order a filter for a 2000 Suburban 6.0L?? Does that sound right?
PS. Deep pan seemed to keep my crusing trans temps down by 15-20 degrees. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">First the filter # 24208576
second do you know the # of the pan you got with the drain. THanks in advance
as much deeper as I get from the pan, that
would totally eliminate the "low tranny
fluid squirreliness" that these 4L60Es
seem to be known for... at least, until
the oil was a whole lot lower. That's
why I want a lower pickup tube even if I
don't "need" it.
