what gear ratio?
Old Feb 25, 2008 | 09:04 PM
LT1_King's Avatar
Default what gear ratio?
I tried a search already but no luck. My brother has a 1993 Z28 M6 that came stock with 3.23 gears. He is running 17x9.5's ZR1's. They are wrapped in Nitto NT555's 275/40 R17. I did the driveshaft and wheels test. Driveshaft spun 3 1/4 turns to 1 tire/wheel revolution. Lug nut was marked and driveshaft also. On the highway @ 70 mph, engine spins @ 2000 rpm roughly in 6th gear. What gears would he have?
Old Feb 25, 2008 | 10:11 PM
Jays00ss's Avatar
More than likely he has 4.10's. I have 4.30's and turn 2150 @75 MPH in sixth.
Old Feb 26, 2008 | 07:42 PM
Razor_Blade's Avatar
That sounds like a 3.23 ratio to me. Check this out http://www.f-body.org/gears/ .
Old Feb 26, 2008 | 08:05 PM
chromeplated500's Avatar
I agree with 3.23s
The RPO codes are as follows. should be on the inner drivers door.
GU6: AXLE REAR 3.42 RATIO
GU5: AXLE REAR 3.23 RATIO
GU4: AXLE REAR 3.08 RATIO
Old Feb 26, 2008 | 08:37 PM
Randy WS6's Avatar
3-1/4 tuner= 3.250" so its a 3.23
Old Feb 27, 2008 | 03:06 PM
96lt1ss's Avatar
3.23s
Old Feb 29, 2008 | 04:55 AM
badazz99ta's Avatar
i dont understand how its 3.23s when i have a 98 m6 z28 with 4.10s and at 70 mph my rpms are right at 2100. not trying to argue, just trying to understand.
Old Feb 29, 2008 | 03:18 PM
Randy WS6's Avatar
To know for shore,you just need to take the cover off and count the teeth and divide them in to each other , Like if its a 4:10 you should have 40 on the ring gear and 10 on the pinion gear.
If you turn the axle one full turn and count how many time the drive shaft turn will get you real close ,if its a 4:10 it should turn 4 full turns and 1 tenth. and a 3:73 should turn right at 3-3/4 turns . Hope this helps
Old Feb 29, 2008 | 04:07 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You definitely answered your question by rotating the driveshaft and seeing how many turns it took to turn the wheels once. When I did this in my new Strange 12-bolt, it took just over 4 turns of the pinion yoke to gets the axles to turn once (4.11s).
