DANA 44 still exist??
I have a Dana 44 in my car, pretty sure the ring gear is 8.5 and my axles are 30 spline. We'll see how much power it can take through my twin turbo sbc.
Probably what will help make it live is i'm not going to use a transbrake.
As for putting one in your 4thgen, the only problem you are going to have is the backing plate issue for the brakes and also there will be no ABS or Traction control.
In all honestly, i planned on getting a 8.8 setup from that guy Craig @ Extreme Chassis i believe because you can get one setup for about $1600. A good dana 44 can run you very close to that if the seller knows what he has. Only reason i didn't go with the 8.8 is because i got the dana @ a very fair price
edit:
you are also going to have to run wheel adaptors to run your stock rims since each side is about 2" shorter. BUT the good thing about that is that now you can run rims with less backspacing
I noticed that it did say "Dana 44 based". I never caught that before. I thought it was a true dana in that car, but it appears that I am (or very well may be) incorrect. I never thought of the 9 bolt as "Dana 44 based", but I guess it could be. Interesting....
I've asked him about it, and this is what he told me:
"the Dana 44 is much lighter than the 9" and has a better pinion angle...cost is around $3000..."
Ouch.. unless you really care for the weight, might as well go for a 12 or 9"
