Drivetrain loss...
For example say you had 350 at the crank and put down 300 to the wheels with a six speed. There is your 15% loss which is 50HP.
Now say you were making 600 at the crank. Is your rearwheel gonna be 510HP and lose 90HP? or is it gonna be a fixed value and lose that same 50hp?
<small>[ February 28, 2003, 02:11 PM: Message edited by: BlakCamZ28 ]</small>
http://www.superstang.com/horsepower.htm
Especially with my TH400... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Pump / housekeeping losses: pump work is
pressure * flow, flow ~ RPM. Pressure is
fixed by blowoff regulator, point in RPM
band where this becomes fixed value is
unknown. Not power output dependent, RPM
dependent.
Gearing Losses: I believe these are also
mostly viscous / frictional losses. Some
RPM dependent (viscous drag), some speed
independent (plain friction). Again I say
this is more like speed proportional, not
power proportional. How much does torque
affect gearbox friction? Should be no torque
dependence of viscous losses?
Torque Converter: Now here, slip is dependent
on torque, as well as speed, this loss will
go up with power.
Some trans mods made for purposes of handling
more input torque (like raising line pressure)
will produce higher parasitic losses (power =
flow * pressure)
