here comes the noise!!
Old Mar 27, 2008 | 07:00 PM
mtxfrk2k1's Avatar
Default here comes the noise!!
ok.. just today i heard a popping sound.. first time it has ever happened...
it sounds like it is coming from the center section of the car.
it only does it when im shifting gears between 1/2 or if im slowing down it will do it every once in awhile.
since i have heard it.. it almost does it every time i am shifting at low rpms or am off the gas then give it gas again...
I still have all power and you can not feel the popping sound at all from inside the car.
what in the world could it be?
Old Mar 27, 2008 | 07:06 PM
EPP's Avatar
EPP
It could be this. Bob
http://www.exoticperformanceplus.com...php?service=58
Old Mar 27, 2008 | 09:13 PM
mtxfrk2k1's Avatar
what other possibilities??
u-joint???
Old Mar 27, 2008 | 09:20 PM
wtomlinson's Avatar
and i thought i was the only one with this problem. i'm experiencing the exact same thing, just kept forgetting to look into it.
Old Mar 27, 2008 | 11:23 PM
mtxfrk2k1's Avatar
it takes all the fun out of the vehicle when you have to worry about something...
Old Mar 28, 2008 | 12:02 PM
mtxfrk2k1's Avatar
well got to get under the car today.
i started wiggling the driveshaft and on the rear i have some play so im guessing the pinion bearing is pretty much history.
guess im going to the part store so i can go tear into that.
Old Mar 28, 2008 | 12:45 PM
goinfast's Avatar
i have the same problem
Old Mar 28, 2008 | 01:34 PM
COOKIE MONSTER's Avatar
Hope it all works out for ya!
Old Mar 28, 2008 | 11:01 PM
mtxfrk2k1's Avatar
what all can i reuse during this.. what all should i replace??
can i drop the driveshaft and insert the front pinion bearing from there. or does it have to go through the rear???
