Breaking rear ends
Old Mar 28, 2008 | 11:24 PM
maxgee's Avatar
Default Breaking rear ends
Curious to know what you did to break your rear end?
Old Mar 29, 2008 | 12:22 AM
bigsticksupra's Avatar
i went to the track on some drag radials and it broke on the third pass. stock everything rear end with girdle.
Old Mar 29, 2008 | 07:15 PM
keliente's Avatar
Went to the track with DR's.
Old Mar 30, 2008 | 07:05 PM
EPP's Avatar
EPP
I read where one guy broke his backing it out of the garage. Bob
Old Mar 30, 2008 | 11:26 PM
99FBODY's Avatar
i broke mine just driving the car when i first got it. the car only had 33k on it when it broke.
Old Mar 31, 2008 | 12:23 AM
addicted2fun's Avatar
I broke mine at a 5500 rpm launch... was pretty cool. i think i cried and laughed at the same time, knowing i had to buy a 12 bolt to do what i wanted...
Old Mar 31, 2008 | 12:25 AM
Oh, that was on a strip with slicks
Old Mar 31, 2008 | 12:38 AM
02 BLK WS6's Avatar
My finger poked through the toilet paper wiping.
Old Mar 31, 2008 | 03:23 PM
Jsonchevz's Avatar
I was dumb enough to let the pinion bearing go bad in mine the first time then the torsen went bad at the track with street tires so I thought I could get away with changing to an auburn pro posi myself and set it up wrong and burnt up my second set of richmond gears and then had to buy new ones and take it to a profesional
Old Mar 31, 2008 | 04:09 PM
ski23's Avatar
Well I finally broke my Posi. %th pass at the dragstrip, I was in the burnout box heating them up, let go of the line lock and CLUNK. I gave her a drop hop and no issue so I staged. Only came out at 1500 rpm knowing she might be broke and got about 10 ft and CLUNK again so I backed off. Drove the car home (about15 miles) with minor issues. I have driven on DR`s for 2 years with 4.10 rear and girdle with welded axle tubes. around 25 track passes and tons of street abuse I finally sheered about 5 teeth off the spider gears in my Auburn Posi. Had the ol` Zexel under the bench so I swapped the ring gear to it and threw in all new bearings/races and shes back.
Old Mar 31, 2008 | 10:03 PM
joker_01z28's Avatar
I put it in drive to go into my garage, not doing anything out of the norm.
Old Mar 31, 2008 | 10:48 PM
sworaz's Avatar
Old Apr 1, 2008 | 01:06 PM
GuitsBoy's Avatar
I had to replace my axles due to some spalling on the wheel bearings, but so far the rear end lives.
Old Apr 1, 2008 | 03:46 PM
trix-storm's Avatar
when i flipped the switch on my 150 shot lol. i killed mine roll racing even.. how pathetic is that. glad i have a moser 9inch now.
