Stock or Built transmission: Which lasted longer?
From what I've seen, stock trannies are lasting longer(miles) than built ones. You guys tell me what lasted longer for you in terms of miles.
LS1Tech Administrator
Received 1,785 Likes
Re: Stock or Built transmission: Which lasted longer?
If it appears that stock trannies are lasting longer, it's probably for one of these reasons:
A) Most of the A4 cars out there that have stock transmissions are not raced and/or abused as much as cars that have built trannies (hence the reason for it being built)
B) Most cars with stock transmissions don't have nearly the power that cars with built transmissions have, and are therefore less likely to break anything.
If you are going to use a built tranny with the same moderate power levels that you would expect a stock trans to hold up to, and if you don't race/beat the car often, than I don't see why a built trans wouldn't hold up as long or longer than a stock one???
Thing is, you have to have a comparison where there are no variables, meaning both trannies (stock and built) are used under the same conditions (whether it be race or cruise).
From what I've seen over the years, there's no question, a well built transmission will always outlast a stock one. It's the simple fact that auto manufacturers aren't willing to spend the needed money to build the best transmission they can for all their vehicles. A transmission that shifts gears harder (automatics, of course), is definitely going to last longer.
It's not a fair comparison when u think about it..
Stock tranny's start out by only having to hold 300hp and gradually as people add mods start to suffer more. a Built tranny has to handle a large amount of power being fed through it from day one.
If someone fed a stock tranny 500hp right away it wouldn't last long at all.
An automatic is only as good as the builder building it, espically in the after market. I've taken stock trannies with little more than 300 miles on them put 400-500 hp in front of them with nothing more than a billett servo and band, and have gotten 60-80 thousand miles, hard miles. Face it guys heat kills trannies, when you don't belive this; remember, heat kills trannies, slipping causes heat, stop the slipping ,stop the heat!!! The biggest part of slipping is knowing when it happens....... These 4L60e's are some good units, alot of aftermarket goodies,to really make em come alive, but more heat related failures than anything else, some bad input drums secound. Just my two cents <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
