Changing rear end fluid
Old May 23, 2008 | 02:18 PM
SSmokin99's Avatar
Default Changing rear end fluid
I want to change my rear end fluid, but I'm un sure on how to do it. Is there any write ups on this? Also what kinda fluid would you guys recommend?
Old May 23, 2008 | 02:40 PM
M-Ten's Avatar
What kind of rear end do you have?
Old May 23, 2008 | 07:32 PM
SSmokin99's Avatar
I have the stock 10 bolt rear end.
Old May 23, 2008 | 07:59 PM
JimsWS6's Avatar
pull the "10" bolts o nthe cover. and pop it off. The gasket might stick alittle but just sue a screwdriver and pry it off. Get a new gasket and 2 quarts of gear oil.
Most eveyrplace has Mobil 1 gear oil, so thats a good call. Any brand name would be fine. But I'd lean towards a synthetic. GM calls forl ike 75W-90 weight, but when I changed my gears I went with a 75W-140 MB1. It's extra thick when hott to help reduce stress on my weak 10 bolt. So I'd consider that also. It cost alittle more but I feel it'll help
O ya it should hold about 1.5-1.75 quarts. Keep it about 1/2" from the bottom of the fill hole, which is on the pass side.
Old May 23, 2008 | 09:41 PM
BOLO's Avatar
Don't forget to add a bottle of GM limited slip additive, regardless of which gear oil you use.
Old Aug 16, 2008 | 04:38 PM
Crimsonnaire's Avatar
How do you know when it's time to change the rear end differential fluid? Or do you have to change it after so many miles?
Old Aug 16, 2008 | 09:35 PM
tee-boy's Avatar
Default dddd
I belive some synthetics like Royal Purple don't need the additive.
Old Aug 17, 2008 | 02:28 PM
BriancWS6's Avatar
Yes, remove the cover and let it drain. I'd just use some silicone instead of buying a gasket when you put it back on.
Fill it up til it comes out the fill hole which is on the pass side. Takes prolly 1 and 2/3 quarts.
Don't waste your money on the **** *** 10 bolt with synthetic. Reg old 80/90 will be fine. And if you have a zexel torsen posi, you don't need the additive.
Old Aug 19, 2008 | 05:35 AM
SS1875's Avatar
Helpful hint when removing the cover don't take all of the cover bolts out...leave a couple of the upper ones in so the cover doesn't fall off and all the fluid splashes out at you. By doing this you allow the majority of the fluid to ooze out(more controlled).
Old Aug 19, 2008 | 10:47 AM
Jawsgear's Avatar
Once a year or every 10,000 miles is what we recommend. More frequent oil changes leads to longer lasting differentials.
Jeff
Old Aug 20, 2008 | 02:06 PM
nightmare23's Avatar
so i need more than 1 quart??? about 1 - 2/3 ...there expensive
Old Aug 20, 2008 | 02:44 PM
Jawsgear's Avatar
Yes, 2 quarts plus an additive. You have to pay to play.
Old Aug 20, 2008 | 03:19 PM
INMY01TA's Avatar
Originally Posted by BriancWS6
Don't waste your money on synthetic. Reg old 80/90 will be fine.
+1. Dino 80/90
Old Aug 20, 2008 | 04:36 PM
ok two...no additive if i use royal purple right?
